Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
4 x cop
itzu tinman
Quote; You seem to have the same current flow values across both CVRs ?No, see screenshot below, there is 4x more current (rms) flowing through CSR2 (70mA) compared to csr1 (18mA).QuoteAs you can see in my last video,where i swap out the CVRs for small DC motors with parallel caps,the one in CVR 2 position starts running well before the one in CVR1s position--why would that be?.Because there is (like you said) more current flowing through the csr2 position.QuoteIn the previous video to that,i show the temperature of each CVR,where CVR2s temperature is some 4 to 5 degrees C hotter--why would that be?Because of the higher current through csr2 (mine has 0.3°C higher temp., but these are 20W csr's).Itsu
synchro1
        GAP power
Art Porter determined that transferring power to a rotor with his magnet core "Neutralization Power" coil was about half as efficient as transferring to linear motion. This is due primarily to the field dimensions of the coils.
Art generated his rotary motion with a flywheel. Tinman's rotor reverses the sheer to push pull power ratio of 3 to 1. The power coil could be mounted next to the Gafenol tub magnet and vibrate it through a range of frequencies and amplitude varying the duty cycle.
synchro1
synchro1
Dragone and Zaev.
A few contributors have offered theories about the magnet core coil gain; mentioning field compression etc. These guys are reinventing the wheel.
Tinman and Itzu need to take caliometric readings of the coil's core magnet. They will find their magnets are cooling.
The PM field is not compressed it is annihilated by a dealignment of polarized electrons caused by the electrical pulse.
The Neo-magnet material has to work on the quantum plane to reorganize its alignment and consumes heat in the process. Electricity is generated by the work.
These are the theories of Dr. Leon Dragone and Nicoli Zaev.
synchro1
The power gain from the "Magnet Core Coil" comes from electron forces within the atomic structure of the Neodymium material not the action of it's magnetic field.
