Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
synchro1
Replacing the switch connections with this Pulse Width modulator suggested by Magluvin, should yield similar results.
The steel jacket makes a magnet rotor impractical. The perpendicularity of the oscillator works better.
https://www.overunityresearch.com/index.php?action=dlattach;topic=3684.0;attach=30973;image
synchro1
Itzu is pulsing his magnet coil at 86 Hertz. An oscillator would vibrate at around 5,000 times per minute pulsed at this frequency like mine. This would generate a lot of power from a piezo chip.
All the circuit needs is a diode between the EM coil and the storage capacitor. This is an over unity design. Just an EM coil the PWM module and a few magnets and voila!
synchro1
Mag's $2.00 PWM has a voltage spread of 3.5 to 24 volts. 12 volts will generate more magnetic coil flux then 6.
The ceramic magnets need to balance the coil field strength. Therefore, We can gauge a neutralization strength by causing the electromagnet to drop a nail with the masking strength.
When we determine the operating voltage we need to adjust the ceramic magnets attached to the EM with add-ons subtractions.  After that we simply program the frequency and pulse duration into the IC; For example 86 hertz at 10%. This should be enough to generate vibrational piezo output along with the super high efficiency of the coil gain.
