Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
Another beautiful solenoid build with a 3 pin SPDT micro roller switch and cam lobe where the third pin is left criminally idle when it could be returning the power pulse.
https://www.youtube.com/watch?v=ZsJkAys2mHI
synchro1
The three pin SPDT basically wires the same way as the four pin because two pins are linked in the four pin leaving three.
The hot coil wire would connect to the center pin, in the 3 pin micro roller, the positive of the battery to one side and the positive to out put on the other. The coil hot wire goes to the conjoined pins on the 4 pin pressure switch. A "flip flop": One side on the other off and vice versa.
The magnitude of the BEMF charge recovery is overwhelmingly abundant. The solenoid motor featured above would go over unity if we wired the switch for output and connected an alternator to the flywheel.
synchro1
We can suspend a very large 4" diameter axial polarized cylinder magnet over a Mendocino base with a track length to match the throw. We can attach the other end to a scotch yoke which would limit the return travel of the magnet piston. The return pressure of the "Ernshaw" repulsion spread out over the length of the track bed, would transfer more thrust to the piston then the mere attraction of a backing magnet. Half a Mendocino with double the base track magnets, supported on the other end by the flywheel connection.
A cam lobe and micro roller SPDT switch on the flywheel would permit the operator to advance the timing to speed it up. Consider how the 3 to 1 sheer to push pull advantage effects the COP.
synchro1
The spring press SPDT switch shorts the power coil to ground through a load after the power pulse and back spike discharge. The switch delay is long enough to allow the inductive kickback to discharge between contact connection. The back spike is annihilatory current running in the reverse direction. The BEMF output from the Faraday effect of the magnet moving inside the coil is current traveling in the opposite direction to the back spike, from the magnetic field collapse and is much higher in amperage.
The SPDT switch does everything this commutator's designed to do: He's just shorting the output directly to ground with no load in between. The BEMF output from this Newman motor would illuminate a bulb, but the tester is not showing that. He's obliquely claiming a 90% pulse recovery.
https://www.youtube.com/watch?v=Cx-ECN86D1Y
