Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
0 Members and 222 Guests are viewing this topic.
Mr.Miyagi
Sorry, just trying to help, if its clear it makes sense.  ;)
synchro1
The high voltage discharge into the electro magnet has zero effect on the magnetic field. The core must be damping the effect. That leaves the thick wire solenoid.
synchro1
I doubled the voltage from 6 to 12 on the 1 Henry choke after the video and got a more powerful very rapid oscillation:
https://youtu.be/GClmc6p6O9k
synchro1
https://www.youtube.com/watch?v=Zubp7Woxt8Y
Compare that hi voltage current interruption magnet direction with the low voltage below:
https://www.youtube.com/watch?v=r8wBt9Q8H5I
The magnet stack in the hi voltage current interruption is not powered by the electrical current traveling from the ignition coil to the ground. The current is traveling sideways through the wire as the hi voltage interruption scours the conductor of electrons and the surrounding magnetic field rushes in to fill the void.
The same thing is going on with the 10 Henry choke and the magnet field. That force is from the imploding ether.
__________________
