Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
"H" bridge schematic. The Stator rocker is attracted to magnet fields of both polarities. The backing magnets to the side and the middle leg magnet of different polarity. The coil pulse neutralizes the center leg and attracts the rocker to the south end reversing the current.
synchro1
This A.C. alternator may power a washtub synchronous motor with the "H" bridge rocker.
kolbacict
Is it possible to rectify an alternating voltage without using a semiconductor diode, a tube diode, etc.?
Using only inductors, transformers, capacitors?
shylo
you could store the positive side in a cap ,
the negative side in another cap,
then discharge in the appropriate order.
but you still need diodes.
artv
synchro1
https://www.youtube.com/watch?v=f4M8Rcb9wWk
This is shuttling a ferrite rod with six Neo disc magnets three on each side in opposition polarity.
There are no magnets in adjacency to the power coil, but the two SPDT switches are reversing the current in the oscillator:
