Negative Inductance and measure of Magnetic force.
Started by synchro1, November 19, 2017, 08:20:57 AM
synchro1
"When an external magnetizing field through a piece of ferromagnetic material is changed, for example by moving a magnet toward or away from an iron bar, the magnetization of the material changes in a series of discontinuous changes, causing "jumps" in the magnetic flux through the iron".
The stator is "Jumping" inside the Bloch Wall! The "Domain Shift" is not confined to the material; The "Jump" characteristic remains the same. The entire area of data switch engineering is devoted to the magnetic frequency characteristics of alloys.
The main point is that we are taping limitless free power from the Quanta!
kolbacict
 not want to be excited  vibrations of the vibrator plate when powered by a dc current.  How many I did not put different magnets around the device.  However, if an alternating current is applied at the resonant frequency, some positions of the magnet do amplify the oscillation.
synchro1
@kolbaciat,
Can you upload a video?
Quote from: kolbacict on March 21, 2020, 03:31:10 PM
Connecting two microwave stators together with 8 magnets of opposite polarity, 4 on each "E" core, with the 2 primary coils only, should amplify the A.C. current like the two shaded pole stators "Tinman" measures his 6 times the power through with a strong Neo magnet attaching them.
kolbacict
well. I'll try. :)
p.s. And the ripple does not crawl from your power supply?
Is the voltage filtered well?
