Graphene provides limitless free energy
Started by Belfior, December 04, 2017, 03:06:43 AM
isawit
It is a well known scientific phenomena, that all atoms "radiate" electromagnetic energy.
At specific frequencies.
how? what is vibrating? what mechanism? what is em energy? what frequency? what is photon?
word salad? description? story?
BS
maxwell lied. there is nothing, no transverse wave in space. what carries electric and magnetic fields?
isawit
Because of the way the atoms share electrons with one another, there are quantum states
in which an electron occupies two atoms simultaneously.
When the graphene drops from a high-energy state to a low-energy state,
An electron is ejected as a result of this quantum duality.
bs word puzzle
how's atom formed? how 2 atoms share electron? why proton and electron don't stick together? what is quantum? what is quantum state? what is energy?
full of bs is your science
citfta
Quote from: isawit on December 06, 2017, 03:43:29 PM
bs word puzzle
Well, is-a-wit do you have any better explanation for how things work?  You sound like a ten year old babbling nonsense.
isawit
isawit
most science you learned are bs.
maxwell and einstein are both wrong on their theories.
light is not wave nor particle.
all my life, search the mechanisms for gravity, magnetism, light and atomic structure. would trade my life for any one. now i got it all, am i happy?
i thanked God. but still empty, life itself is still a mystery. best i can do is to share my finds.
to see the universe from an atom, give you logo pieces, you can build all kinds of toys.
gravity is simply induced electrical attraction force between neutrally charged masses/matters. similar to sexual attraction outside marriage.
the greatest 2 physics laws tell the secret already.
f=Ke x q1q2/rr and f=G x m1m2/rr both forces decay at 1/rr, must have same nature.
HOW ATOMS ARE FORMED
1 electron carries 1 negative charge
if we smash the electron into 1000000 equal pieces, each piece will carry 1/1000000 negative charge. Let's call it enertron.
since enertrons carry the same negative charge, they repel each other.
if we have a perfect bottle, which means no leakage, no react, like glass bottle to air.
we put 1000000 enertrons into the perfect bottle, since enertrons repel each other, they put a pressure on the bottle wall. let's measure and call that pressure 1 volt.
if we put 8000000 enertrons into the same bottle, the pressure on the wall should be 4 volts.
now if 1 enertron is moving or vibrating, the rest all enertrons will be energized.
that is the mechanism of light/quantum.
now if we put 1 positive charge into the perfect bottle, what will happen?
enertrons should be attracted by the positive charge and form a ball around it, the closer to the positive charge the denser enertron cloud. the density of the enertron is decay at 1/rrr due to the repulsion force between enertrons decay at 1/rr.
now image enertron is the real thing, it carries a tiny negative charge, something like 1/10^33 electron charge, but it has a stronger force field, similar to neodymium magnet compare with iron magnet.
image proton actually carries 918 positive charges, it attracted 917 total charges of enertrons formed a solid ball, 1 electron attached to the ball to form a neutrally charged hydrogen atom. 1 atomic weight equals to 1936 total charges, no matter positive or negative charges.
this is the realistic atomic structure. the electrons are constantly vibrating on the plane at 90 degrees to the atom radius due to the kinetic energy it carries.
atoms are solid balls, matter is not compressible.
if atoms are constructed as science told you, 99.99% empty space, why matter is not compressible? electron shell/wave/cloud/orbital are negatively charged, they do not stick to positive changed nuclear is a magic, how can they stand any force/impact/reaction without crashing?
why is energy conserved?
if you put a moving force on any electrons with a force, that force is spreading to all the lines of sight electrons instantly by the repulsion force between them f=Kexee/rr, they all are moving now, and cannot stop ever.
do we have a perfect bottle?
yes, every atom is a perfect bottle. all matters are a perfect bottle. energy has nowhere to go but bounce within and between matters.
the forces f=Ke x e1e2/rr and f=G x m1m2/rr are like perfect springs between/within matters, connected all matters in 1.
MAGNETISM
2 parallel wires at r distance, the free electrons in the 2 wires repel each other with force f=Ke x q1q2/rr, that force is the carrier of energy/moving electric force/emf. that force act as a class 1 lever with the fulcrum at the center, the mechanical advantage is equal to 1.
if electrons move in wire 1, electrons in wire 2 will instantly have opposite direction emf. the true mechanism of electromagnetic induction. same as momentum conservation.
every magnetic atom/magton contains 2 atoms. 2 atoms of a ferromagnetic matter before magnetize, we put it as 00. if 1 electron moved from 1 atom to the other atom and stays there as -11, the 2 atoms become a magton, it carries a special property now, we call it magnetic force.
-11, -22, -33...-nn are all magton, but carry different magnetic force strength.
2 magtons attract each other in the direction -11><-11, and repel each other in the direction -11<>1-1 or 1-1<>-11.
use copper wire winding around an iron core, put a current, the electrons in the wire move in circles around the core, make atoms in the core arrange into -11-11 directions all the way. on the pole plane area, magtons are arranged as clockwise concentric circles of -11-11 directions, north pole.
reverse the current direction, the pole plane area magtons are arranged as counterclockwise concentric circles of -11-11 directions, south pole.
so, a magnet north pole stored clockwise electric force, south pole stored the counterclockwise electric force. the same poles always repel, different poles always attract.
the earth magnetic field is a mistake. there is no field but the force in the universe. sunlight moves electrons moving westward causing earth magnetic force interact with compasses.
there is only 1 force exists, coulomb force f=Ke x q1q2/rr. gravity and magnetic force are both different configurations of electric force.
without matters, there is no force. a single matter has no force. force can only exist between matters.
without a test body, where is the electric or magnetic field? where is gravity field?
the mysteries of the universe are within 2 equations.
f=Ke x e1e1/rr and f=G x m1m2/rr.
those 2 forces rule everything existing.
the mechanism of quantum entanglement is simple. the force between any 2 charged particles f=Ke x qp/rr is the carrier of energy/information/moving electric force. it is an invisible physical rod with zero mass that always connected 2 particles as 1. if 1 particle is energized, that energy instantly transferred to another. from f=ma, m=0, so energy instantly moved from 1 particle to another. we call it QE
enjoy it, question me or see more at fuckedscience.com
