The secret to Overunity
Started by Tajerek, December 17, 2017, 07:40:33 AM
Quote from: smokyMy HV source provides infinite instantaneous current.
No, it doesn't.
1+(-1)= (sqrt)-1^2
No, it doesn't.
13.6eV + (-13.6eV) = sqrt(-184.96)
No, it doesn't.
18.2(X10^-31)x(300(x10^6)^2x1.6(x10^-19) =5.1^5Coulombs
That is what is released in the collision
:o
Wish I had some of whatever you've been smoking!
Merry Xmas !!
Void
This thread is a good reminder of why it is so important in the OU research area that people be
able to back up what they are claiming about OU with some sort of proper test setup.
Even then, if a test setup can't be shown to be self-sustaining over a reasonably long enough
period of time, then there is still always good chance for people overlooking important things influencing
the test setup results, or measurement error, etc.
A truly self-sustaining setup that can be shown to be self-sustaining for a reasonably long enough period
of time depending on the exact setup, would much more likely to be showing genuine OU, if it is not just a trick.
The reality is there are no shortage of people out there making all sorts of claims about OU, but much more often
than not it seems they can't back up what they are saying with a proper demonstration in a reasonable sort of way.
It's a sad statement about our world that there are so many 'mistaken' people out there making so many unfounded
claims about all sorts of things, but it is the unfortunate reality of this world it seems.
Season's greetings to all... :)
May you not be led down the garden path even once in the coming new year! :)
SolarLab
F.Y.I.
Some additional insight regarding "capacitor behaviour" also may be gathered by studying:
Electrophorus or electrophore: Wikipedia {note: classic books/papers might be a better technical
source - refer to some older posts for some excellent book links} - "a.k.a. capacitive generator."
Discovered/Invented by Johan Carl WILCKE 1762 - Alessandro VOLTA 1775
https://en.wikipedia.org/wiki/Electrophorus
Volta Electrophorus - possibly the original "first perpetual (OU?) free energy mechanism!"
[basically - charge it once and, under ideal conditions, the device will retain it's charge while, at the same time,
deliver a sustained output - it will self-replenish it's original charge]
Further concepts are developed here: About the relativity of the potential energy of the capacitor
{all 5 pages plus refernce links]
http://gorchilin.com/articles/energy/capacitor?lang=en
Note: I add these "F.Y.I." references on occasion when it appears to me that a promising thread reaches, what I will call,
a "Ground Hog Day" moment {I won't elaborate further since we all know what I mean}!
Hopefully, like we do in real life, we will pause and revisit, or renew, or re-think our process and approach.
FIN
Void
Hi SloarLab. Although it should already be very clear, nowhere in this thread was anyone
suggesting that OU is definitely not possible, if that is what you are implying, and most
of my comments here were in direct response to specific things Tajerek was claiming, as some
of the things Tajerek was claiming were quite obviously based on misunderstandings of basic principles.
Electrostatic induction was already mentioned as an aside in this thread, but this wasn't what
was being discussed by the original poster. Electrostatic induction is a very interesting effect, and
it potentially holds some possibilities in OU research. It could possibly be the working principle behind
the 'testatika' device for example, if that is a genuine OU device. I have experimented some with
electrostatic induction, but so far wasn't able to produce anything beyond small but still interesting effects.
All the best...
Grumage
Hello All and Merry Christmas.
This is an area of research I will be looking at in the New year, when I can reliably obtain the ingredients to make wax Electrets.
I have an idea of a simple attraction motor. Your thoughts on how it might work, if at all, would be appreciated.
A disc of thin Aluminium sheet is covered by a slightly larger diameter of Polycarbonate. The Polycarbonate disc has got slots milled through its thickness. These slots extend from the centre point radially, just the same as the segments of a Wimshurst machine. I cook the wax mixture and pour into the slots cover with foil then pole the assembly with a positive potential applied to the base disc. I make a second one done the same way.
The poling voltage is going to be 20KV DC from an " air purifier/Ozone/Ion " generator module.
I then propose to mate the two discs back to back and provide an axle to be fitted into a pair of bearings mounted in a vertical fashion. The final part is a " U " section metal " attractor " ?? That goes to a good earth and is placed so that the rotor can run between the faces. Finished!
Cheers Graham.
