The secret to Overunity
Started by Tajerek, December 17, 2017, 07:40:33 AM
sm0ky2
@Tinsel
Have to performed the experiment of discharging two oppositely
charged Leyden Jars, independently
To Earth Ground?
And comparing this to the dual-discharge to each other?
the results vary slightly depending on the machine used
and conditions of the experimental environment
But what do these results tell you?
And how does that change your view on how we use electricity
in our modern equipment?
I can show you this mathematically on the atomic scale, it is how your semiconductors
function in your computer.
Even the basic form of a schottkey diode demonstrates this.
This is how we bridge the gap inside a transistor, or turn "on" a vacuum valve.
They buried Tesla over this. And hid his work for long enough to establish their wasteful
process of throwing 1/2e in the trash to charge us $$
We are just breaking the surface on what a positron actually 'is'.
But the math for it already exists. We label the numerical value as a "lack of electron"
Or "electron hole".
The math is the same. Math doesn't lie. Just the people describing it.
We can argue over the semantical existence of positrons, but at the end of the day
We have a numerical conundrum.
If you like: Call it an atom that is missing its electrons and has also
some magical ability to defend from environmental electron absorbtion.
It's the same.
We declare this at the elementary level, then 'forget' the equal and opposite value when we
apply the charge to our circuit. We ground it out and call it "0V"
You don't see the problem with this?
Why does static electricity, when stepped-down, still spark through almost anything it finds?
Our 1-sided electricity does not do this as the same voltage levels.
When we step-up our modern electricity to HV it is not the same as what is produced by
Our induction machines. We can see this when we experiment with it.
it's not the same substance, because the old form uses Both halves.
sm0ky2
And for the record, my 4-ft acrylic disk turns everything I own into a conductor.
Including rocks, plastics, glass, wood, concrete, and the 5/8 thick acrylic itself.
I estimate it to be over 1M after the first few seconds at 60rpm
5-gallon bucket caps click at faster than 6hz
And if they are too far apart one of them goes through to ground.
White paint bucket or the orange Home Depot one.
Which tells me I need to step up to a larger cap if I knew why material to use.
At 10-12 nf we're talking about moving a joule in nanoseconds.
How many million Amps do we need for it to be considered
'countably infinite'?
SolarLab
Hi Void,
Please let me quickly clarify; my post was primarily geared toward suggesting a re-think
or expansion of "capacitance concepts" by way of referencing some electrostatic (electrodynamic)
principles.
BTW, I find Tajerek's approach to be, for the most part, consistent with those that
are sometimes presented when discussing electrodynamics with respect to capacitance. It's not
uncommon to use varying theories when discussing a subject, based on the process you are
attempting to describe.
Plus, I'm not sure the "displacement" part of Maxwell's equations (or at
least the revised version by Heavyside, et. al.) has ever been adequately resolved.
The Electophorus reference was provided to accentuate a change in charge (Q) of a capacitor
without the need or use of apparent electron flow as is defined in conventional current (i).
I hope that after reviewing the attached supplements you will appreciate my submission, at least
to some extent. Also, since these forums are not frequented to any extent, there's a lot that I miss.
FWIW. Briefly, one focused objective here is to review promising (working?) devices, theories and
concepts mostly by way of mathematical description(s) and prototype; such that further CAE/CAD
modelling and analysis can be employed to technically verify the approach; or at least point out
areas where current theory may need enhancement, modification or a complete re-write. The next
step so to speak!
And hey - that electrostatic wheel thing (see above) some fellow did on Youtube a while back - at
least we know it doesn't work as claimed using conventional theory... those one's are easy to
analyze and simulate!  Don't be too harsh - some of the the "masses" crave (need) their fake news!
Best wishes to one and all. May the "Clause" be with you!
SL
Void
Quote from: SolarLab on December 24, 2017, 05:41:12 PM
Hi SolarLab. I guess you didn't follow the discussion too closely then. He really
wasn't making any sense that I could see, based on what his circuit diagram shows.  ;)
It was not a discussion of electrostatic induction. No worries however.
All the best...
sm0ky2
Both theories are correct in their own respect.
In one way the capacitor charges inductively
Change in charge induces opposite charge in the same way
that a moving charge induces its opposite.
In the other way, the capacitor is charged through brute force
Current
in either case, it becomes charged.
And discharges a given amount of energy based on the formula that was mentioned.
The math supports both theories, in the way in which they are applied.
