The secret to Overunity
Started by Tajerek, December 17, 2017, 07:40:33 AM
Grumage
wattsup
@Grumage
A question if possible. On your video, are the two non-moving balls secured to their present position in any way?
Observation: If they are, since the balls are 6" dia. and since the travel between the balls is 1 foot, maybe you can take a small thin wire coil tapped to the top of the center ball with a thin insulator while the center ball is centered between the two end balls and put that on a scope as it moves left and right.
The question I would have is what are the actual movements of the ball. It is a steady smooth movement or is it a collection of jagged micro nudges that are nudging the ball in each direction?
wattsup
Grumage
My dear Wattsup.
There's no way on earth I'd put my scope anywhere near 40,000 volts!!
Yes the end spheres are quite well anchored using Blu tack.
Another way might be to do a short clip taken at high speed and then watch in real time?
The centre sphere is always charged up to the potential that each end has, positive or negative, that charge acting then to repel itself away and become attracted towards the other end.
Cheers Graham.
SolarLab
Quote from: Grumage on December 26, 2017, 11:09:27 AM
As promised.    :)
https://www.youtube.com/watch?v=-4XlD4YP5Kc
Cheers Graham.
Hi Graham,
Thanks for the spec's, Excellent!
Looking forward to reviewing what several premier CAE tools come up with.
May take a little while - have to set up the analysis and fit in some workstation time
[some of these take days to run, fix, and re-run].
Glad you clarified the florescent tube mystery - 40KV - at first glance, well - you
know - tubes are dark?   ;)
Quite an impressive scenario you developed!
SmOky2 - maybe a good "optimization goal:"
  Voltage vs Size/Weight vs Distance/Speed?  Academic? - not entirely...
Also: recall Prof. Gerald H. Pollack, University of Washington, book/videos
"Fourth Phase of Water;"     ""Likes like like""" ???   Starts about 9:20 in video;
https://www.youtube.com/watch?v=i-T7tCMUDXU
   And; Water => free energy discussion at about 12:50.
Anyway, sometimes things may not be exactly what we "think" they should be. Oh well - TBD.
SL
