The secret to Overunity
Started by Tajerek, December 17, 2017, 07:40:33 AM
blueplanet
Quote from: sm0ky2 on January 06, 2018, 09:52:11 PM
@blue
Magnetic flux can be demonstrated
It is short lived, as it disappears as the conductor reaches the max charge.
the magnetism only exists while the change in potential is occurring.
when the electric field is oscillating, the magnetic does the same.
At high voltages the magnetic field strength is very small
increases in conductivity at high voltages reduce inductivity
but it does still exist.
Any use of relativity theory will lead to discrepancies with maxwells work.
Because Einstein did not finish what he was doing. And left part of the equations
unhandled.
I don't think this means Maxwell was wrong, but perhaps we need more information
to make his equations fully translatable at all levels.
I did not say Maxwell was totally wrong.
In a conductor, this oscillating magnetic field is parallel to the surface but the quantity can be extremely small compared to the voltage. That's where high characteristic impedance comes from, i.e. high electric field and  extremely low magnetic field. Inside a low-loss dielectric material, this magnetic field is possibly not measurable. If there is any measurable magnetic component, it is mostly like along the surface of the dielectric material.
By Poynting theorem, the power which can be transferred should be close to zero.   But the experimental facts suggest otherwise.  Unfortunately, all these Zenneck's stuff are too controversial to talk about.
(PS. I am talking about electrostatic waves.)
blueplanet
sm0ky2
the orders of magnitude are inversely proportional
In the same way that voltage and current are in the power equation
The same power can be represented by low V, high I
Or high V, low I
The same occurs with the electric and magnetic induction
because of the time constraints
above threshold voltages (800kV+) this drops to roughly
9.3x(10^-21) Joules per Tesla per volt per meter^2
when we factor out the Weber, we find that at high voltages
the magnetic moment is a very short pulse.
imperceptible to us, but not to a low-energy electron.
it stays at this strength until the other threshold, where matter change states.
then there is no induction, magnetic or electric.
Only charge. The electrons (charge carriers) have fled the scene.
(~2MV)
blueplanet
Quote from: sm0ky2 on January 06, 2018, 11:42:11 PM
Or high V, low I
(~2MV)
There are circuits that require only V to work. Not I. The eventual output power is not VI.
A movement of charge carriers will produce a conductive current, which in turns produces magnetic field. There is no argument against it. The magnetic field which you were talking about was possibly a conductive current of some kind.
A change of electric field also produces a current. This current is called displacement current. This displacement involves no movement of any charge carriers. This displacement current has been proven to be able to do work in some rare situations. But this current does not yield any meaningful magnetic field.  Are you sure you have been able to measure a magnetic field with a displacement current?
Blueplanet
