Kapanadze, Stepanov, Barbosa-Leal and the Secret of Free Energy
Started by Zeitmaschine, December 21, 2017, 12:05:17 PM
leonelogb
Quote from: tomd on August 19, 2018, 03:47:32 AM
One person can't save the world. However many people may do just that. The more people that are aware of this and are able to replicate it the more difficult it is to suppress. This is the only way we will progress beyond the current energy paradigm. It has to come from bottom up, because it's certainly not coming from top down.
Onepower is right, we can all be heroes, but we are always going to need help from someone, nobody is so perfect that he does not need help from another, even Nikolas Tesla; He got intellectual and economic help from others, to achieve his goals.
okay
First, we need to understand well what we are going to build before going back to the work table ...
If we want to pull energy from the ground you have to attract it, (these are words of a disappeared genius) ok, Tesla was working with a transformer which he call the Disruptive Discharge, Tesla himself expresses how it was construction , this was formed in the secondary by two coil in series one in cw and the other in ccw the center of this was attract to pull from ground therefore it was connected to ground .... OK,  I'll need little help in this part ...
The other thing is that he discovered a strange behavior when he put the circuit of the secondary in short circuit with a copper bar, I think something happened with the eddy currents, capacitance and high self inductance of the secondary that it made this current (eddy) run back and forward and if we take one point of it join and put it to earth this will do attract to those electrons that the earth contains in an infinite way, Well this is the second part to test and then we will see.
peace!!!
tomd
I have extracted the essence of patent application DE102006054568A1. As you can see this is all about negating the cemf from secondary to primary. How it actually does this I am not 100% sure. However it seems the following is important:
a) There are two primary coils and one secondary coil.
b) The polarity of magnetic field does not change
c) Capacitor(s) connect with coil to form a phase shift and/or resonant circuit.
d) The phase shift is such that one coil is at its max while the other coil is at its min.
1. At present, electric power is generated by generators that convert mechanical energy into electrical energy. It is characteristic of this
    type of induction that the magnetic field of the induced current brakes the rotation of the rotor, resulting in that the generator more
    mechanical energy must be supplied, the more current is generated.
2. The object of the invention is to produce electrical energy, the magnetic field of the induction coil only very small, ideally has no effect
     on the energy supplied to the generator more.
3. the polarity of the magnetic field is not changed
4. capacitors can be connected with coils to the phase shift of current and voltage to change or to form resonant circuits.
5. The apparatus for carrying out the above method according to the invention characterized by at least two coils which generate
    magnetic fields, wherein the supplied into this coil voltage such effect that a coil just has a maximum magnetic field while the other
    coil has a minimal or no magnetic field , These coils are matched by its winding direction, the polarity and the time course of the
    injected voltage that their magnetic fields that are coupled magnetically with at least one other coil, that produce a rectified voltage, in
    this further coil wherein the magnetic field of said further coil the they causing magnetic fields hardly, no longer opposes ideally.
6. The method of the invention allows an induction of electric voltages, whereby the generated energy of the applied energy is no longer
    or hardly counteracts this and consumed thereby.
7. According to Lenz's law an induction voltage is always directed their cause counter, which results in the inventive generator, that the
    magnetic field generated from the secondary coil at the rise of the magnetic field generated by the first primary coil pair itself
    generates a magnetic field whose polarity to the magnetic field of said first primary coil pair is directed against. However, since the
    magnetic field of the second primary coil pair is being weak due to the supply voltage, the magnetic field of the secondary coil is
    rectified to the magnetic field of the second primary coil pair and therefore forms a common magnetic field with this what to leads that
    the magnetic field of the first primary coil pair is not or hardly through the magnetic field secondary coil is attenuated.
Belfior
Quote from: tomd on August 20, 2018, 02:41:05 AM
similar patent
https://patents.google.com/patent/WO2013104041A1/en
granted US patent for a self runner
US3247407A
tomd
A few things:
1. As we have a closed core, no matter where the secondary coil is positioned it will be between the two primary coils.
2. The current in one primary has a 90 degree phase difference with the other. This will result in the magnetic filux of one coil strengthening
    while at the same time the flux in the other coil is weakening.
3. The primaries are positioned with their poles NS or SN.
For example lets say the primaries have adjacent poles NS and the north pole coil is strengthening while the south pole coil is weakening. By lenz law the secondary will oppose the stronger north pole coil with its own north pole. At the same time it will hold back the weaker south pole coil with a north pole. Obviously an electromagnet with two north poles is not possible. So what is really happening here?
tomd
I've had to change my stance on this as primaries positioned with opposite poles adjacent is a no goer. I now believe the primaries are positioned such that like poles are adjacent and the secondary in between.
How is cemf defeated?
Lets say the primaries have north poles facing each other with the secondary in between.
The magnetic flux of one of the primaries is gaining in strength this causes a north pole on the secondary in opposition to the primary. However this is balanced by the other primary where the magnetic flux is declining. This causes a south pole on the secondary and the magnetic flux would be aiding the first primary.
Bear in mind that magnetic flux induces voltage and the primaries are in parallel. So the net effect is that cemf (voltage) is not reflected back on the primary.
