DESTROYING Energy
Started by EHT, January 28, 2018, 03:06:03 PM
0 Members and 17 Guests are viewing this topic.
EHT
Quote from: gravityblock on February 02, 2018, 07:18:50 PM
Let me simplify this for you and the others, since my word experiment is somewhat confusing.
A good example in how COM (Conservation Of Mass) holds while COE (Conservation of Energy) is violated can be seen in transferring the momentum of a heavier mass to a lighter mass, according to KE = 0.5 * mv2.  It's known by top physicists that Newton's zeroth law is invalid.
A 5 kg mass moving 1 m/s has 5 units of momentum and has a kinetic energy of 2.5J.  A 1 kg mass moving 5 m/s has 5 units of momentum and has a kinetic energy of 12.5J
12.5J > 2.5J !!!  <------ Conservation of energy is violated when transferring the momentum of a heavier mass to a lighter mass, while the 5 units of momentum is conserved!
Gravock
The confusion here is that momentum is not a conserved quantity in this example. Momentum is mass x velocity and NOT the same as energy. You cannot transfer momentum and expect the same energy because they have different equations.
IF a 100% transfer of energy between the masses were to be effected, then it would result in the 1kg mass having a velocity of sqrt(5) m/sec - approx 2.236 m/sec
Mass 1kg. Energy=2.5J
V=sqrt(2E/m)
=sqrt(2 x 2.5/1)
=sqrt(5)
=2.236 m/sec
E=(mv*2)/2
= 1 x sqrt(5)^2/2
=5/2
=2.5J
Ask any "top physicist" (or just a "normal" physicist, for that matter) and they will tell you the same.
gravityblock
Quote from: EHT on February 03, 2018, 12:25:42 AM
V=sqrt(2E/m)
=sqrt(2 x 2.5/1)
=sqrt(5)
=2.236 m/sec
E=(mv*2)/2
= 1 x sqrt(5)^2/2
=5/2
=2.5J
Where did I transfer momentum and received the same energy in my example as you have falsely asserted?  Where did I use the same equation for both the momentum and energy in my example as you have falsely asserted?  I used mass x velocity for momentum and 0.5 * mv2 for the kinetic energy!
5 kg mass moving 1 m/s = 5 units of momentum (mass x velocity).  <-------  KE = 2.5J (KE = 0.5 * mv2)
1 kg mass moving 5 m/s = 5 units of momentum (mass x velocity)   <-.------  KE = 12.5J (KE = 0.5 * mv2
As you can clearly see, momentum is a conserved quantity in my example, which you falsely asserted was not a conserved quantity in my example!  Also, energy is not a conserved quantity in my example, which you falsely asserted that it is a conserved quantity in my example.
2.5J is not the same energy as 12.5J!  I never transferred momentum and expected the same energy in my example because I used different equations for the momentum and energy.
You're clearly trying to mislead the reader!
Gravock
gravityblock
Quote from: gravityblock on February 03, 2018, 01:28:29 AM
Where did I transfer momentum and received the same energy in my example as you have falsely asserted?  Where did I use the same equations for both the momentum and energy in my example as you have falsely asserted?  I used mass x velocity for momentum and 0.5 * mv2 for the kinetic energy!
As you can see, momentum is a conserved quantity in my example, which you falsely asserted was not a conserved quantity in my example!
Gravock
Four false assertions by EHT in a single post!  This is an interesting pattern developing from EHT...ROFLMAO!!!!
Gravock
gravityblock
Quote from: gravityblock on February 03, 2018, 01:39:02 AM
Gravock
....and EHT falls flat on his face like the Double Domino Effect (wait for it)!  Additional angle of the Reverse Domino Effect.
Gravock
EHT
Gravock
I'd bet that the readers here are not as easily misled as you seem to think.
