user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
0 Members and 36 Guests are viewing this topic.
otto
Hello all,
@Grumpy,
there are only vertical lines with a lot of hash, nothing else.
Again,
                     HAPPY NEW YEAR
Otto
Grumpy
Hash? Vertical lines?!?!
Make a series noise "clipper" with  two diodes (signal or zener) and a shunt resistor to get rid of that crap.  U se zeners if noise is high enough to foward bias signal diodes.
NOTE: use only one diode to cut out negative or positive signal entirely.
Also, connect collector to collectors - not collector to control.
PS - Happy New Year - just opened to lid of the candy jar.
        -Frank Edwards
aether22
SM has DC output, and I think it's important to focus on getting that if your really trying to replicate SM. (measure your collectors for DC!, DMM or analog!)
Now assuming he didn't just rectify the output then he somehow found a way to induce DC which is not in the least possible with EM induction. (nor with parastatic capacitance)
One way this has been achieved is in the tubes which were used by Swiss ML, Ed Gray and Tesla in his tube powered car.
But we know that SM finally used solid state circuitry, and while it might be possible to turn radiant energy into DC with the right degenerate semiconductors we know that's not how he did it.
Most likely he used the same effect that Markovitch and Coler used, and maybe Brittan and Stubberfield assuming they were DC, possibly Perrigo and Swiss ML (look at the coil around the conductive? crystal) too I think.
With Coler it was established at the time that the iron cores of the Stromerzeuger were where the energy was generated, with Markovitch it looks like it must be the mast (unless it's simply a result of the aether flowing through any copper wire, which it may be), and if the mast coil generated a voltage and the mast didn't then it would have shorted, the silver core developed the voltage seen in that device. (the mast coil may or may not have helped)
Now it strikes me that current flowing parallel to a magnetic field is likely to spin and vortex (point a magnet end on to a crt), maybe this is why SM says that the wire should not be braided?
The electrons should be given enough room to move (freely spin/vortex) inside the conductor, not forced to follow a braid.
This would suggest thicker wire actually.
You may also want to place a 90 degree coil in parallel with the collector, in exactly the same way Markovitch's mast is wired with the silver core and winding in parallel.
If you get even milivolts of DC (if using a digital multimeter swap the leads to see if the polarity reading reverses) then you know your on the right track.
BTW I have been studying radio reception with underground and special antennas, also looked at stubberfield and I totally understand how it's working.
So you may want to test your TPU (or two TPU's one transmitter one reciever) because that would be an excellent way to see how energetic/radiant/aetheric you are getting it. (all you need to transfer energy wirelessly is aether/orgone/radiant electricity, more of it the better, a resonant receiver and importantly you need to start the process  which won't be difficult if you have any detectable EM)
Actually you may even try putting transmitter coils around a TPU ring, with 3 tuned reciever coils rotated to the right or left 120 degrees (better yet 130) relative to the transmitters, each transmitter outputting a different frequencies that only the one coil has any resonance with, aether is then moved in a circle by the power transfer.
Very interesting stuff, I do recommend looking into: radionics, CHTA, pat GB2075755 at espacenet,  Stubberfield's battery and low frequency transmission system and underground radio articles at borderlands.
The crux of all of these and Markovitch and all other FE devices that have antennas and grounds is that resonant transfer of energy creates an aether flow which in normal radio reception is minimal due to the atmosphere by default not being that energetic, but if your antenna is a caduseus coil (see CHTA) for example which it still releases some normal EM then as soon as you tune into it the signal gets much stronger as you have established a flow of aether which carries along with it the signal of the transmitter.
note: an underground antenna can still pickup above ground stations well because the radio waves are impressing themselves onto the ground and those telluric/aetheric (it's all the same stuff given many different names) currents are being impressed, but ground radio can only send to ground radio generally.
Actually the Markovitch device for example only receives the EM to establish the aether flow, it clearly serves no other purpose.
Also borderlands has some great info on all of this.
The aether flow carries fields with it, Boyd Bushman found the magnetic field from his compressed magnet device (that falls somewhat slowly) to go an awfully long way.
Here is a report from Bil Beaty's amsci site: I was building a electromagnet and It was starting to look good. I had put a switch on it to divert the power at my will. Also, i had added a miniature Tesla coil to the design for optimal power. when i hooked it up to a 9 volt battery and i held up the screwdriver which I had wrapped the wire around to magnetize. i was able to take my other hand and metal objects would attract to it as if my hand were a magnet.
The TC is an aetheric pump (That's what Tesla said) and the aether carries the magnetic field with it.
Moray could tune into sounds in distant locations, he simply had a means of tuning into the earth energy at a certain location and with that he received the sound from that location too. (He might have had to use something to receive the sound, not sure)
Another example is that if you have say a 10mhz signal + connecting to the receiver with a powerful aether stream and you also have a 2mhz transmitter near the 10mhz transmitter (or probably just anywhere in the path) then the aether stream created by tuning into the 10mhz signal causes the 2mhz signal to be dragged along. (I have yet to try this, but have reasonable confidence it could work)
Stubberfield transmitted the human voice by using huge coils of wire to impress a low frequency non radio signal on a large area of earth, because earth (as well as air of course) has, again whatever you want to call it, aether, orgone, telluric currents and by building it larger he simply encounted more of it to impress the low frequency EM on.
Tesla however used pancake coils which have been observed to make a beam of aether even unpowered. (the secret to Tesla's system isn't in the transverse vs. longitudinal debate, the greater secret is in creating an ether linkage, which may indeed by more effectively established by longitudinal)
If you look at enough of this stuff it builds coherent pictures you can't miss it.
giantkiller
Quote from: aether22 on January 01, 2007, 09:11:00 AM
Well put and all very close to the mark.
A number of us have 2 or 3 coil MTs and a large # number of us have TPUs. This experiment should be easy to do. I am finishing Otto's config. Then I will throw the MTs in the mix.
Nothing too complicated, just numerous combos to try.
It's a new year, so let's try to get free!
aether22
Thanks Giantkiller,
BTW I'll challenge you on something, your main assertion is that the reason you pulse with a fast rise time, short duration and fast fall without any reversal is to resonate a shockwave that makes many frequencies 'sing'.
While I won't argue with you that it will, nor that it may be key to getting some devices to work, IMO if you wanted to 'ring the bell' you'd be best to keep it on for a while as it would dramatically increase the range of frequencies effected, and furthermore reversal wouldn't be such a big deal.
The reason you need the above specs is because as Tesla and others have said you are pumping the aether.
(I have long thought such impulses were moving the aether, but only recently became sure)
If you can suggest an ideal circuit I'd greatly appreciate it, something with a shockingly fast on time and short impulse and naturally zero reversal, otherwise maybe we can brain storm the perfect one? (preferably faster than the average propperly driven MOSFET)
Also, if we are trying to stop electrons from moving maybe we should be using chokes which shouldn't stop the aether in the least.
Also if you switch from the negative side (so it's always positive) you will have fewer conduction electrons, I think Ecklin actually suggested such a thing.
I think I'll try putting this through a big pancake coil which will be inline with another pancake coil which I will tune, then as an addition I'll see if I can get two coils put in or around this beam (shot out of the hole in the pancake coils) to transfer more energy from pri to sec. (50 hz air core transformer).
