user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
starcruiser
Here are a few caps from the vid Turbo posted. it looks as if there are 2 wires to the right side transistor and maybe 2, definitely 1 on the left side. The small grouping of components on the left gets the red wire from the coil.
Can you make out what the core is made of? Kinda looks like tin foil or a metal core.
Regards,
Carl
Dansway
Here again is what Turbo has posted:
so this would be the most simple coil.
it is not the most powerful ring.
the wires do get hot.
it cancels the flux in a certain way the electrons are free to move.
it still does need a 9 volt battery for the OSC.
it needs to speed up a bit without the load otherwise it wont start at all.
no magnets are used.
Potential eddies are capable of a structure formation, and they spread due to their particle character as longitudinal shock wave in the area.
RE (radiant energy) shock waves actually auto-intensify when encountering segmented objects.
The segmentation is the key to releasing the action.
This shock wave does not pass through the windings of the coil but treats the surface of the coil as a transmission path.
The RE wave is quite different from the electromagnetic field generated around a wire.
Some coils will be better if they are wound as *-filar serially-connected coils, which just means that the wire used to wind them is multiplied over from certain point(s) before the coil is wound.
The reason for this arrangement is that the magnetic field component of the coils is (nearly) zero as the current flowing across the wire is flowing in opposite directions in alternate turns, and so the magnetic field produced should cancel out.
High voltage high frequency alternating current between two metal objects create a solid state "space" exhibiting the attributes of mass, inertia and momentum.
etc. etc.
Hi Turbo!  I want to thanks you for sharing your knowledge on RE Shock Waves.  Can you toss a few more bones to us hungry dogs?
Thanks again!
~Dan
gn0stik
well, I was wrong about who I thought it was. I was pretty damn sure too. Bummer.
Well, here's hoping that Turbo is open minded about sharing schematics, etc.
Rich
Pontifex
hi gn0stik,
maybe you are not wrong about who you thought it was.
I speculate that this time he just wanted to toss a very big bone to us ["so this would be the most simple coil"] and waits for replication attempts...
Greetz, Pontifex
gn0stik
Hey Pope,
Maybe. but I don't think I thought what you think I thought. (whew that was a mouth ful)
I thought it was Marco, and he said that it was definitely not him. The reason I thought that is because of some things he said, about cancelling flux and whatnot. Also, the video format, and quality is similar to some of his past posts. I thought perhaps it was the same camera.
At any rate, turns out that it's not him. He actually laughed at me.
Oh well.
