user TURBO?s replication of Steven Mark?s TPU ?
Started by turbo, November 29, 2006, 04:13:49 PM
CTG Labs
 :o
Just something interesting for you all.  Now please do some work for yourselves, you are not helpless!
http://www.padrak.com/ine/WALTON696.html
"Each energy level has three unique frequencies, also due to the constructive and destructive interaction of the three frequencies produces a specific composite energy level." The levels may be designated 1 through 4, with 1 being the highest. For our purposes the frequencies are not important (they vary from 1021 to 1024). What s important is the relationship these frequencies have to each other within their respective energy levels.
By interfering the frequency relationship of the highest energy level such that the particular frequencies we choose generate earth resonances as one of its heterodynes, we can create a most powerful field that actively interferes with the earth's magnetic envelope.
The frequency ratios of that level are 1;4; and 5, or in musical terms: do, fa, so. By selecting as representative frequencies 48Hz; 64Hz; and 72Hz - but moving the three down just a hairsbreadth so that the heterodyne of the two highest frequencies becomes 7.83 Hz, we achieve just that.
Since the quality of the actual energy level is that of Scalar Standing Waves, longitudinal in nature, using sound waves can simulate or mirror their interaction if the medium through which we convey them is ionic.
I set up a waveguide with three arms converging to a center, each on a 120 degrees leg. Each leg was cut from square cross-section PVC gutter pipe and measured to correspond to an exact fraction of the wavelength for one of the frequencies, that is 12, 9 and 8 inches or multiples thereof. Transducers capable of producing 120dB in the medium selected must be used and these are placed at the ends of the cavities. Measurement is done from the face of the transducer to the point of intersection."
Generating the required frequencies is relatively straightforward and we should start with a master oscillator with fine incremental tuning operating at 576Hz, this is coupled to three buffer amplifiers whose outputs are taken to: 1. A divide by 8 which = 72Hz 2. A divide by 9 which = 64Hz 3. A divide by 12 which = 48Hz.
All three are then taken via a square to sin convertor and to the transducers vial power amplifiers. Not being partial to noise, not least 3 x 120dB, I am considering the possibility of alternatives to the above. Do beware of "Pop" music groups standing in a circle, do not stand at the focal point or you might just become closer to heaven than you would wish.
**No claims are made by myself and the above is passed on purely as a gift. On the basis of my own investigation I would suggest there is a better than average chance of success.
Yours sincerely, Donald P. Walton
tomas
a lot of electro dudes know that a high frequency high voltage discharge is not measurable with a digital multimeter.
the meter just goes crazy and shows something like HV 8888.88.
also the average camera locks when using such fields, in fact all usb equipment fails at this stage.
so, should they buy expensive equipment only to prove to you its real what they are showing you?
i think not.
maybe you would be better off trying it yourself because then you would realize very quikcly how difficult it is to measure such energy flow.
T.
Dansway
YES...!  YES...!
DAVE....you are AWESOME...!   Thank you DAVE!!
Nice...
My brains is loving this....!
Thanks DAVE!
~Dan
AhuraMazda
MeggerMan
Hi Dave,
Thanks for the info, it looks quite involved with the 3 merging frequencies.
From your video demo I thought that you were powering the bulb with no input power at all, so you do require the 3 inputs to power the output (collector)?
Just to prove that I have not been idle I decided to build a motor to try and prove the Mehess motor.
Operates on 0.028v at 0.34mA with 50% duty cycle, so around 5uW.
Has to be driven mechanically as electronics is too power hungry and requires a higher voltage.
Just need to see if the output can exceed the input.
It is made from ceramic 8 magnets on a CD cake box and has a polished steel and saphire bearing, same as in your mains electric meter.
Rob
