WARNING Cant believe what im reading
Started by tinman, February 22, 2018, 08:03:31 AM
tinman
author=Magluvin link=topic=17619.msg517031#msg517031 date=1519339933]
QuoteAs you have highlighted in red, of which seems to be your point of contention, do you disagree with that there would be no drag or as he says bogging down when current is drawn from the gen?  If so, what is it dragging against if the disk spins with the magnet together?
I do indeed--dont you?.
What is it dragging against?--dont you know Mags?.
Have you not played with homopolar motors?
Do you think there is no drag?
Are you saying we could put 100 homopolar generators on a single axle,drive it with 1 small electric motor,and produce 1000's of times the output to that of what the motor is using?.
I am surprised Mag's--i thought you knew this stuff.
Brad
Magluvin
Quote from: tinman on February 23, 2018, 04:18:16 AM
Brad
If you spin the disk magnet with the copper disk together, as in they both turn at the same speed, and load the current produced in the disk, there will be drag on the drive motor? If so, and you can show this, then we have something else of great significance that we can talk about.  ;)
Mags
tinman
Quote from: Magluvin on February 23, 2018, 05:44:33 AM
Mags
Of course there will be drag on the drive motor when you load the output Mag's,otherwise we would have a reactionless generator.
