Omnibus
There's ample empirical evidence even at this point proving that CoE can be violated.
It cannot be emphasized stronger that to prove violation of CoE it is not mandatory to demonstrate continuous production of excess energy, that is, it is not mandatory to demonstrate a self-sustaning device. Demonstrating discontinuous production of excess energy is as conclusive a way to prove CoE violation as the scientific method requires. This is extremely important to understand if you don't want to get discouraged at every step of the way towards building a perpetuum mobile. Now we know perpetuum mobile is possible and that's the most important stalwart basis of our pursuit. The rest, the physical building it, is only a matter of engineering skills and infrastructure.
fletcher
Quote from: Omnibus on February 09, 2011, 11:06:54 AM
Not so omnibus !
Case in point :
We all know how to create Ke [Energy of movement] with magnets - just have a linear array like a Smot, Gauss gun etc & as long as you place the ball in the field the ball will accelerate & gain a final velocity, Ke & momentum.
That result did not violate CoE or Thermodynamics - we did Joules of Work [F x D] to place the ball inside the attractive filed - thereafter the field potential accelerated the ball giving it a velocity & Ke.
So, exactly like a gravity field you must do Work to give a mass Potential which then provided it is free to move will acquire velocity & Ke [Joules of capacity to do Work] - the Force is the mass x acceleration the field provides - the Work able to be done capacity is the Force x Distance the ball moves etc etc etc.
It is hugely important to show OU via continuous production of excess Energy, that can either cover system losses &/or do external Work i.e. Output is greater than Input.
Showing a gain in velocity & Ke using linear magnets shows a discontinuous process, BUT it cannot restore the Potential & show excess Energy available to do external Work etc.
So, exactly as not accounting for the Work Done in raising a masses Potential in a gravity field, so is the partial budgeting approach of not accounting for the Energy Input into ANY system [including magnets] that hopes to be OU, completely erroneous logic.
The Smots & Gauss guns, Milkovich pendulums etc of this world are fascinating but not a single one AFAIK has managed to close the loop - in each & every case we are always told it is just a technical hitch, much as you keep propounding - well, it's not a technical problem that can be solved by mechanical aptitude, only a matter of applying of competent engineering skills & infrastructure as you've repeatedly said - it is a matter of understanding Thermodynamics & the Laws that filter down thru them to see the fallacy of the argument about "only a matter of a mechanical engineering solution".
The brand of soap box selling of partial truths you promote re:
QuoteDemonstrating discontinuous production of excess energy is as conclusive a way to prove CoE violation as the scientific method requires.
is disingenuous & deceiving to the researcher who should be armed with accurate information - it will be his epiphany that breaks the shackles of physics & lets him produce the first closed loop OU mechanical system, but that won't come from continuous disinformation & false direction.
Omnibus
The problem is that you don't understand exactly how the devices mentioned by you violate CoE. This is obvious by the way you have explained why they don't violate CoE. Therefore, you cannot appeciate at all that to prove CoE violation, as has already been done definitively, demonstrating continuous motion is not at all necessary. Let alone that theoretical mechanics itself contains inherently violation of CoE in its very core, as I've already shown.
fletcher
The simple & only answer omnibus, is then close the loop with this excess Energy, to validate & prove your point !
No other discussion is required !
Omnibus
Quote from: fletcher on February 09, 2011, 04:22:02 PM
Like I said, that's an incorrect requirement if scientific method is to be honored.
