0 Members and 73 Guests are viewing this topic.
ltseung888
The diagram in reply 2690 is modified to use available equipment and set up.
The Frame of the Yuen Wheel can be modified for the experiment.
One or more of the 4 availabole bicycle wheels can be used.
Need to contact a machine shop and a motor/generator retailer in Hong Kong or Shenzhen.  Try to work out some mutually win-win arragement.
sarkeizen
Quote from: ltseung888 on March 03, 2015, 07:23:41 AM
How much would this cost? I might be willing to fund this provided you can demonstrate a reputable way to test this AND when it fails you post a video of yourself on youtube - saying you are the deepest and most complete sort of moron.  Post it here under your name and never post about free energy again. :)
ltseung888
An improved experiment design?
Some existing QMOGENs are already placed side-by-side.  The addition of an Unbaolanced Cylinder serves both as a flywheel to store energy and as a lead-out energy device.
It will take them little effort to check out this improvement.  Let them shine...
Paul-R
Quote from: ltseung888 on March 03, 2015, 02:00:21 PM
Probably not.
The output of the generator is not likely to please the motor.
Ideally, the motor should be a low voltage DC and the output of the generator should be rectified (if necessary) and fed to a battery which then supplies the motor at its stated voltage.
Low-Q
The vibrating unbalanced wheels inertia will slow down the motor when you try to take this energy out of it.
You cannot get more energy out than you put in. These QWERTYUIOPASDFGHJKLZXCVBNMGEN designs follows the laws of physics just as any other thing on earth. Nothing new or different just because a wheel is bouncing around due to its unbalanced features.
Vidar
