0 Members and 103 Guests are viewing this topic.
Dingus Mungus
Thanks FE,
You always handle such posts much better than I do...
example:
@Artman
Are you really claiming that 10 components
in one sim is too much for my computer?
Read the graphs... Understand the graphs...
Want more proof? Build a pendulum, its easy.
Just not worth my time and money right now...
You've seen the evidence and it means nothing to you...
If I were you I would just spend my time on something I believed in.
(Linard Griffin H2, Mike motor, SMOT, TPU)
~Dingus
hartiberlin
Quote from: i_ron on February 17, 2007, 12:41:24 AM
Quote from: Dingus Mungus on February 17, 2007, 12:22:20 AM
A very nice prototype...
So the motor will only turn untill the pendulum trips the pressure switch, then gravity takes over again. I also like that your counter weight is adjustable, as well as the levers pivet point. So I assume the pannel box is you speed controler. How has your system harmonics hunt going? Congrats again on the really dynamic design job.
Glad to see someone is really putting a propper effort in to exploring this technology.
Best design and prototype I've seen in a while,
~Dingus
Thanks for th kind words, Dingus,
The blue box holds the logic and the Fet to pulse the motor.
The motor has one coil and three magnets on each rotor. To fire the coil only on the down swing I chose to use a quadrature encoder, as seen in this picture on the front.
The opto's for the coil are just ahead of the motor. When the secondary beam is
allowed to oscillate also, it requires more input to the motor, no surprise here.
To accommodate this I added two more windows to the opto's and two more magnets
to the motor from my original four magnet two window 5 watt model... and a doubling of the weight. This is just enough power to allow a limited vertical displacement of the pendulum pivot point. The counter weight is two 25 pound bar bell weights.
At this time I have not attempted to extract power from the secondary arm, rather
I have been side tracked back to a couple of previous generator projects. I will not
post more on this until such time as I have "caught up".
R
Hi Ron,
very nice professional setup.
I hope you will get it running and can post more infos.
Can you do some measurements of the output power already ?
And then compare against your used input power for the
motor driving your pendulum ?
Many thanks.
Regards, Stefan.
i_ron
[/quote]
Hi Ron,
Many thanks.
Regards, Stefan.
[/quote]
Thanks Stefan,
The output arm needs the restriction of a load in order for the pendulum to work
properly when it's pivot point is allowed to move. I have been investigating various schemes but haven't settled on one yet.
It has been a pleasure to work with Veljko on this. He is genuine, sincere and
offers much support and encouragement.
Regards, Ron
