ltseung888
The precision mechanism challenge.
The same problem arises again.  Eight years ago, we used the proximity switch in the Tong Wheel to provide a solution.  That turned out to be a "mistake".  The approximate solution a sort of worked and much time and resources were wasted.
This time, we shall seek the best solution first before any "build".  There is no pressure to get a working device.  Many UFOs are flying.  Many QMOGENs are working.
I am sure that China and USA have solved this problem in their top secret projects.  The 225 HP Pulse Motor solved this problem too.
Can any forum member meet this challenge and benefit the World?
Lawrence
reply 3354 3355
memoryman
Almost any rotary encoder would do; of course it's a waste of time.
ltseung888
Chinese Student:  "The Flying Saucer theory is very simple.  The Chinese translation of centripetal force is "force towards center".  The Chinese translation of centrifugal force is "force away from center".  I can easily understand that when you swing the magnet very fast in a circle, the force away from center is much higher."
Almost all Chinese Students understood the King David Sling scenario right away.  Are there any forum member not following the King David Sling scenario?
If the theory is this simple, how can USA and China keep the top secret?
Lawrence
reply 3354 3355
ltseung888
Quote from: TinselKoala on May 31, 2015, 10:51:42 AM
For Lawrence's specific application, a rotary shaft position encoder with 4000 line per revolution resolution and a simple microprocessor control (Arduino for example) would be better, I think. Digital is always better, isn't it? :)
The rotary encoder wheels, kits, sensor/interface etc are available from USDigital and aren't too expensive.
http://www.usdigital.com/products?gclid=COLkh_Wc7MUCFYoYHwodRQQAcw
So the position of the rotating part can be read to 1/4000 of a complete revolution by the Arduino, and the pulse edges can be set to occur at any specific line count in that range by a couple of simple potentiometers connected to the Arduino. The necessary program code is almost trivial to implement, very basic line counting and analog-digital read-write statements using ordinary potentiometers to set the pulse edges. Or if timing and dwell need to be varied automatically with rotor speed or other parameters, the Arduino can be programmed accordingly to handle that.
The technology proposed by TK may be a possible solution.  Any comments?
Any other proposals?  Have we got all the major pieces of the puzzle identified?
The Drive Coil needs energy.  Can the Collector Coils provide that (with extra left over?)?
If we use ferrite core, the efficiency can go up over 1,000 times.  Can we be using the already available electron motion or electron cloud energy?
Which Nation will implement it other than USA and China?
Lawrence
reply 3354 3355
Paul-R
Quote from: ltseung888 on June 22, 2015, 04:47:34 PM
Not "may be" but "is".
A bit over exotic. Remember Occam's Razor. Most people would be happy with a Hall effect switch costing a few shillings and a couple of extra components. Or whatever is specified for the Robert Adams device.
It is a simple problem with a simple solution. There is no need for mind bending accuracy or resolution in order to establish the merit or otherwise of the basic concept. In my view, as a variant of the Adams, it is interesting. As interstellar propulsion, it is dead in the water. There will be an out of balance wobble but to do anything with it, you will need a ring the size of the Large Hadron Collider, a magnet the size of Ben Nevis and a few nuclear power stations to drive it. You'd be better off with a TT Brown type set up with a rather large array of photovoltaic cells. At least that would work if there is a nearby a star.
