ltseung888
https://www.youtube.com/watch?v=SK1MjVrkY-k
Hot rod products.  The rod and crankshaft appeared to be exactly what we need.
Buy existing products.  Save money and time.
Hopefully, the completed Chan Wheel will be out withing weeks.  One pull and forever running - using lead-out gravitational energy?
http://www.hotrodsproducts.com/
An ebay search on crankshaft turned up an used one for USD75.  The Chinese used parts may cost much less.  Looks like that there is no need to do any design.  Just select and buy.  Chan Wheel should be out in weeks if not days.
Updated Chan Wheel presentation file is attached.
ltseung888
Video showing that the Balanced Chan Wheel cannot lead out gravitational energy.
http://youtu.be/Kqtp4-X6TGI
This is the most common mistake for the Pulse Motor Inventors.  One must have the oscillation or vibration or the Lee-Tseung Pull to lead out the gravitational or magnetic energy.
Compare with this video
http://youtu.be/FolD_R32Eqw
The Unbalanced Chan Wheel showed the Milkovic 2SO effect.  Gravitational Energy is brought in.
The comparison convinced many Hong Kong Researchers to add an unbalanced wheel to their inventions.
ltseung888
Now that the Chan Wheel has been fully described and that Mr. Peter Chan and team are waiting for parts, I shall turn the attention to the Yuen Wheel.
The Yuen Wheel starts from a different point of view:
1. If an unbalanced wheel is needed to bring-in gravitational energy, how about using two unbalanced wheels?
2. If we arrange them side by side with a common axle, one will affect the other and vice versa.
3. If when the weight is at the top of one wheel and another equal weight is at the bottom of the other identical wheel, one will provide maximum torque to help to provide rotation to the other when it is at the maximum height position.
4. If gravitational energy is brought-in, the brough-in energy may be more or equal to overcoming frictionThe Yuen Wheel will then rotate forever.  It is another form of the Bessler Wheel.
5. The design is much easier.  See attached diagram.
ltseung888
HK$1,000 has now been allocated to develop the Yuen Wheel.  The money comes from the "red pocket" money of Ms. Forever Yuen.  She will have a Wheel as a present for her birthday!
The breakdown is as follows:
1. Two old bicycle wheels at HK$40 each.
2. Two lead Weights from fishing shops  at HK$40 each.
3. Frame parts to build a support similar to the Chan Wheel at HK$200.
4. Bearing and steel rod at HK$200.
5. Screws, nuts and other parts at HK$100.
6. Miscellaneous at HK$340
Labor and design costs are free (voluntary).  The Yuen team will compete with others to come up with the Forever Running Wheel to benefit the World.  The success will be the reward.  It is likely to win the overunity prizes in this Forum and other competitions around the World.
Some Venture Funds already promised to invest Billions if any Wheel can lead-out energy and run continuously for 2 weeks.  Many Politicans and Academics are waiting for the public demonstration.  The Yuen Wheel will be free for the World to copy and replicate.  Other wheels such as Wang, Tong and Ting Wheels will be commercial ventures that can provide 5KW or more.
There is no need for the Chinese and USA Military to keep the 225 HP Pulse Motor a secret any more.  Once they release the technology (backed up by the Lee-Tseung Lead out Energy Theory), the energy crisis will be over.
HK$1,000 is approximately US$130.  Almost any household in Hong Kong can afford it.  Every family is a potential "angel investor".  Money is not a problem.  Volunteers are not a problem.  Technical knowhow is not a problem.  The Yuen Wheel will be developed in the coming days.  It is likely to be completed before the Chan Wheel that is waiting for parts.
Thank you to the Almighty for the Divine Guidance.  Amen.
ltseung888
Drawing inspiration from the Peru Energy Multiplier.
http://www.youtube.com/watch?v=dPe1zB5JQmU
The Inventor was very, very close to inventing the Yuen Wheel that will rotate forever.  Without the Lee-Tseung Lead Out Energy theory to guide him, he had to experiment his way and took on complicated paths.
If he had used two unbalanced wheels instead of one unbalanced wheel and one balanced flywheel, he would have been home!  However, he deserves much credit.  He provided inspiration and confidence that the Yuen Wheel will succeed even before construction.
