seychelles
yep all true but if you try to pump water with a hand pump it is the hard but when you connect it to the gravity assist mechanism it make it much much easier..it not just mickovich but also with these guys in America..but also with physics gravity comes into the formula..https://www.youtube.com/watch?v=rxIRaJlTD4Y&feature=youtu.be this is the answer..different but the answer..
seychelles
i reckon if everybody contributed $100 each to duplicate  MR SKINNER GRAVITY MACHINE we could easily see an over unity machine before the end of 2016. Instead we waste our time spending time money and effort on pedantic bullshit little projects that do not lead to nowhere..
ltseung888
Discussion with an Engineer.
1.  A simple pendulum needs to overcome air resistance and the friction at the pivot.  That can be very small.  We can easily achieve 99% efficient.
2.  If the simple pendulum is connected to a seesaw in the Milkovic 2SO fashion, the up and down motion of the weight is automatically maintained.
3.  The maintaining of the up and down motion is NOT via static forces but via the centrifugal force.  Please study the Raymond Head video 6 very carefully.  The weight is lifted twice for every finger push.
4.  The centrifugal force mechanism is "free" by the pendulum swinging motion.  So long as the pendulum swinging motion is maintained, the up and down motion of the weight is also maintained.
5.  The up and down motion of the weight can be used to do work - such as producing the loud bang, crash nuts or pump water.  In the Raymond Head video, the pendulum swings back almost to its original position.  The up and down motion  of the weight produced the loud bang and must have done some work.
6.  One possible explanation is that gravitational energy has been led-out in the process.
7.  The simple pendulum is not very efficient as the energy led-out is occurs at the highest centrifugal force position.  Or when the pendulum bob is at the lowest position.
8.  We can improve the Milkovic 2SO by replacing the pendulum with an unbalanced wheel - the Chan wheel.  The rotational speed can be increased and more gravitational energy can be led-in.
9.  We can further improve the Chan Wheel with Cylinder.  A Cylinder can be thought of as many wheel put together side-by-side.
10.  We can further improve the mechanism via leading out of electromagnetic energy.  A ferromagnetic magnetic material can be thought of as many tiny magnets arranged in random when there is no electric current.  If DC current is passed, these tiny magnets can be aligned to produce a large magnetic field.
11.  The Tsinghua University Energy Multiplier leads out both gravitational and electromagnetic energy.  The Output can be 30 times Input.
Search the keywords "ufo propu" to get more information...
Merg
Unlike various complications, two-stage oscillator has a clear principle.
Image (1)   Fc – Centrifugal Force, Fg – Gravitational Force
Ideal addition of forces in pendulum – culmination is in the lowest position and zero force is in upper position. In addition, there is a difference in potential during the oscillation.
Image (2)
The pendulum – lever system or two-stage oscillator principle: the pendulum oscillation on the left causes the oscillation of the two-arm lever which can result in useful work (mechanical hammering, water pumping, etc). Archimedes (c. 287 BC – c. 212 BC) worked on lever and Galileo Galilei (1564-1642) on pendulum, and the combination of the two results in new mechanical effects.
