A fresh look at the Clem motor
Started by aussiebattler, March 18, 2018, 04:34:56 PM
aussiebattler
aussiebattler
Quote from: sm0ky2 on April 19, 2023, 06:03:08 PM
place a mass on a string and tie it to a force scale
Now: create 2 things:
First a venturi suction junction
Second a Schauberger vortex inverse spatial force.
Now using the force scale, allow the mass to be sucked into the force.
Compare the two, and tell me which one is closer to Clem's results
Please send me a drawing showing how to do that with 8 nozzles doing 3000 rpm  while in a closed oil system.
Another thing
Once you have exhausted the "energy" within the hot oil (whch is insde the device  before exiting thru the nozzles) , how will there be any energy left to turn it?
ab
onepower
aussiebattler
QuoteOnce you have exhausted the "energy" within the hot oil (whch is insde the device  before exiting thru the nozzles) , how will there be any energy left to turn it?
This is a common problem, similar to a mechanic trying to debate at a physics convention. It's this continual dumbing down to the lowest level of thinking which has led to most of our problems.
First, if were going to talk about energy we need to understand what it is and how it works. Energy is not "exhausted", consumed, depleted, destroyed or used up. Energy is conserved and cannot be created or destroyed only transformed. We cannot lose or gain energy but we can transform it to change a process or alter the action vs reaction.
Whenever I work on a technology I use a primer to set the narrative.
https://bigthink.com/starts-with-a-bang/atoms-greatest-miracle/
We need to expand our thinking not dumb it down.
This is another good read.
T.H.Moray, THE SEA OF ENERGY IN WHICH THE EARTH FLOATS
AC
ramset
Compression makes heat
Once heat is at design parameters for an
"Event"
The Event takes the wheel and provides the power
To "rinse and repeat"
A diesel works this way ..
The phase change method should also work similar ..
One minute mark in this vid https://m.youtube.com/watch?v=wkAbV-yXy0M
A threshold is reached where huge "event" manifests to loop
Or run !
  Tom is actually going to work with simple test chamber at first ( no need to
Build a running prototype, just show the power in one snapshot)
Keeping it as simple as possible is the goal ( test bed)
Regardless
It's a cool experiment ( one of many similar experiments with water /super heated steam .. "Sam leach" lithium claim etc etc ..on the table )
Tom has soo many test beds from previous experiments.. he can do all manner of mock ups
At amazing speed!
Myself
I would also luv to understand the method suggested by OnePower and Aussiebattler
Can a simple test bed be produced for "snap shots" ?
Vacuum pressure etc etc ( towards manifesting the claimed gain mechanism?
From the sea of energy or ... ( phase change is sort of doing that with molecular manipulations!
Utilizing heat through pressure..
Thanks Grandma
aussiebattler
Pardon my ignorance but I still dont see of any preposals to convert the energy of the "explosion " into useful rotational energy. Sure in a diesel engine that is done in a combustion chamber, But there is no talk of that here. It would be like letting off a fire cracker in a skyrocket - using up the available fuel
