Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
listener192
Quote from: d3x0r on April 20, 2018, 07:22:43 PM
There is never an 'all coils off' ....
According to Jerdee's chart, step 24 on the 36 slot scheme and step 20 on the 30 slot scheme are  all coils off.
So  my question still stands  regarding the 36 slot scheme using relays, how would you recover coil energy through high side diodes only, without any negative connection to allow current to flow?
L192
pmgr
Quote from: listener192 on April 21, 2018, 02:51:28 AM
L192
There is always a connection to ground through one of the closed bottom relays. The BEMF voltage on a coil can be higher than the capacitor voltage, so current can still flow into capacitor.
PmgR
d3x0r
L192
I looked back through the last few pages, I see no chart like that.
http://overunity.com/17653/pierres-170w-in-1600w-out-looped-very-impressive-build-continued-moderated/dlattach/attach/167603/image//  translated from
https://youtu.be/vii6o20_Vv8?t=25s
There is never a time when 0 LEDs are on except step 0.
The first step, 2, 26, 14 are on.
step 24 (25) wraps back to the start...
https://youtu.be/vii6o20_Vv8?t=38s
that LED pattern and what's in original videos matches.
There is either an LED that's out, or a transistor that is blown so the LED doesn't have much voltage backing? or there's wires crossing in front of it that cause a shadow, but there is never a time when all LEDs are off.
( from here http://overunity.com/17653/pierres-170w-in-1600w-out-looped-very-impressive-build-continued-moderated/msg520053/#msg520053  )
d3x0r
So...
If there are 6 poles, energizing the south opposite any particular north... then the field is north through the center, but doesn't the magnetic path then prefer to go to the near sides, and only a vary small portion actually all the way across?
Could this be run as a bedini with all coill north instead?
But from the rotation, and the code evalutaitons; what makes this different from any other 3-pair of n/s poles around ?  (Like morin Gerald's motor) and many other stepper motors in fans and stuff...
For experimentation I'd think you'd get a higher initial activity by activating only 1 pair at a time, and aligning the center pickup coil ... well I guess if it is cycling all the way around (which the iniital iron filings demo didn't really show to me) doesn't really matter..
But then there is a difference in the voltage from luc's setup to the original demonstration
also having the coils in series divides their current by 2 (double the resistance, double the inductance) rather than activating them in parallel...
seaad
I made a time gap (all transistors Off ) in my SIMulation with recovery diodes.  The amperage is recovered for a short while. See pic.
Quote;
"....you managed to rotate the magnetic field....
....but there is something crucial that is missing which I see none of you have thought of yet since you are too concentrated on a replication....
....I can see that no one has ever ask the real question
of how to make current and what is happening by breaking down the cycle of a generator.
If you really understand this then you will be able...."
