Pierre's 170W in 1600W out Looped Very impressive Build continued & moderated
Started by gotoluc, March 23, 2018, 10:12:45 AM
d3x0r
d3x0r
@gotoluc
30 pole, 5 pitch, suggested pairing...
would run you know like a Harley... stochastic engine something :)
Or maybe just 2 pairs...
d3x0r
Quote from: cheors on April 26, 2018, 05:09:05 PM
We can probably remove 36 transistors and drive relays directly with Arduino outputs:
https://www.ebay.fr/itm/8-Canaux-5V-Relais-Module-High-Low-Level-Trigger-avec-Isolation-Optocoupleur/253428066457?hash=item3b017d6899:g:K38AAOSwhilaaYup
Yes there's lots of those; even at newegg, amazon, ... I found one relay module was 16 in a plexiglass box for like $24.
can even get solid-state-relay versions...(err nevermind SSR; too leaky; too high voltage requirement)
gotoluc
Quote from: d3x0r on April 26, 2018, 04:33:43 PM
@gotoluc
Interesting d3x0r
Thanks for sharing
Luc
BTW, today I took all my stator coils out and reinstalled them to a 5 slot space (pitch) instead of 6 and when I was done, now the windings look exactly like Pierre's stator.
I must of also had an error in the winding sequence since it is a drastic difference. I'm hopping this solves the low output issue.
I have no idea how I had the coil sequence before but now I feel confident it's done right seeing it looks like Pierre's.
Pictures below is, first, my Stator windings before, then Pierre's Stator windings, then my rewound Stator. Notice how the windings now curl.
