Jeg
Does anyone know what is that orange sheet at the internal of the stator? I thought it was paint but now looks more like a sheet of something.
ARTMOSART
Quote from: cheors on March 31, 2018, 02:30:03 PM
L'interrupteur 1 haut est fermé (S1H).
L'interrupteur S7L est fermé.
Le courant circule de L1 à L6. D'ACCORD.
Quelqu'un pourrait dire quelle est la prochaine étape quand le programme Arduino envoie un second digitalWrite pour fermer d'autres commutateurs ?
Switch 1 high is closed( S1H).
Switch S7L is closed.
Current flows through L1  to L6. OK.
Somedbody could tell what is the next step when the Arduino program send a second digitalWrite to close some more switches ?
si j'ai bien compris ,l'étape suivante sera :
S2H fermé et S8L fermé, (note à ce moment L1 et L7 sont en court circuit pendant le temps de la transition) .puis alors S1H et S6L seront ouvert ,le champ est donc décalé d'un pas ;puis ca continue
selon le même principe
EN:if I understand correctly, the next step will be: S2H closed and S8L closed, (note at this time L1 and L7 are in short circuit during the transition time) .Then S1H and S6L will be open, the field is shifted by one step, then it continues  according to the same principle
listener191
Attached is a scope shot showing voltage and current across 6 coils in series (25mH) total. 30 slot stator 36 turn 22AWG coils.
Using the half bridge parallel arrangement i.e. OUT 1& 2 tied together In1 & In2 tied together.
Nearly 4A peak at 31VDC applied. Of course if you slow down the pulse rate the pulses become square and more current is drawn.
The L298N's I have don't have any heatsink compound between the device and heatsink.
Placing some compound between improved the heat  dissipation but after several minutes at this current  raised the temperature to 80deg C and climbing, so either more heatsink area or forced cooling required.
To get these current pulses to square up at say a 1ms period more rail voltage is required.
I have 1 BTN7960 board coming, I will test this but the board is limited to 28V however, the RDS on for the MOSFET's used in the device is reasonable and will reduce volt drop across the half bridge, therefore increasing current through the coils.
L192
listener191
This shot is monitoring the current into the board, from the DC supply, same period as before approx.
The negative going portion of current is that returned to the supply.
L192
