listener192
Diode connections.
72 diodes one diode each side of each coil, to accommodate the flow of current in either direction from an active high side or low side switch.
There are only 36 wires (approx) from the stator to the main wiring board, so how are these connections made if only the coil junctions are brought out on wires from the stator?
L192
seaad
@  listener192
Page32 Reply #477, Page33 Reply #482
One connection  point:  coil    relay    2xdiodes
T-1000
Hi All,
As I also bought Arduino Mega 2560 and now looking again through original Pierre's code and there is interesting moment about coils LOW state:
Quote from: Pierre on April 22, 2018, 06:36:32 PM
1)  digitalWrite(1,HIGH), digitalWrite(13,HIGH), digitalWrite(25,HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(x);              // wait for a second
2)  digitalWrite(2,HIGH), digitalWrite(14,HIGH), digitalWrite(26,HIGH); // turn the LED on (HIGH is the voltage level)
3)  digitalWrite(1,LOW),  digitalWrite(13,LOW),  digitalWrite(25,LOW);     // turn the LED off by making the voltage LOW
4)  digitalWrite(3,HIGH), digitalWrite(15,HIGH), digitalWrite(27,HIGH);   // turn the LED on (HIGH is the voltage level)
5)  digitalWrite(2,LOW),  digitalWrite(14,LOW),  digitalWrite(26,LOW);     // turn the LED off by making the voltage LOW
6)  digitalWrite(4,HIGH), digitalWrite(16,HIGH), digitalWrite(28,HIGH); // turn the LED on (HIGH is the voltage level)
When it is set to LOW from Arduino that mean the relay switch is also active and have coil connected to the negative terminal?
If that is the case 36 out of 72 relays are activated and connecting to the negative then as soon coil X activates. The coil X-1 have opposite direction when its state is LOW.
Which mean opposite magnetic field polarity previous to coil X. Which is resulting cancelation of magnetic polarity in pickup core. Then coil X+1 activates and we get more stronger magnetic field on positive and positive magnetic polarity and resulting more positive field.
Please correct me if that is not true.
Cheers!
d3x0r
Quote from: T-1000 on April 22, 2018, 06:36:32 PM
Hi All,
Cheers!
The relays would be active when the LED is on and no other time.
2 relays are enabled for each single output; one driving the N side and the opposite S side.
at '2' on (N). '18' will also be on (S); but when '18' is on 'N', it's paired with 2 'S'.
and just a minor note
falstad sim was playing with having 2 coils coupled as a transformer, and wiring it in series/parallel.  It achieves maximum current in 1/6 the time in parallel.
dole
Hi,
Firstly I would kindly appreciate if someone has time to analyze
and secondly if had any luck to copy deleted YouTube video:
1.Can anyone help determinate polarity of the "spinning" permanent magnets from published video
   (170W in -1600W out) in slow motion, referring to timeline from 02:25 - 02:39 and 05:31 - 05:51?
2. Does anybody can help providing download link of the previously published video,
    where is "how to" assembly, step by step,  two small "DC" motors, (one with extra opposing magnets),
    100% free energy "building tutorial", running each other by rubber band, pulleys and capacitor.
Download Link : ??
(That it may have some benefits later)
Thanks,
d.
