Brilliant concept, but will it work?
Started by Low-Q, April 22, 2018, 04:29:27 PM
fritznien
i think it takes energy to expand the bellows at the bottom.all the gain is lost on reset.
Low-Q
Quote from: fritznien on April 23, 2018, 11:11:51 AM
That crossed my mind too. On the other hand, that force is perpendiculary to rotation because the pressure outside each bellow is angular to the surface of the discs and can seemingly not force counter rotation.
Just one way to find out.
I print out bellows with some flexible filament I have, and see what happens 🙂
Low-Q
Quote from: webby1 on April 23, 2018, 01:07:11 PM
If one end of the tube were a solid ball fitting into a socket on the wheel and the other wheel had a ball and socket with the tube going through the ball you would only need to seal the one side,, that is the ball and socket and the sliding tube.
Just a thought,,
Yeah. That would be an approvement. I think the biggest concern is the leak around the circumference of the large disc.
If just the device could pump the water leakage back into the "tank". If that device worked, and the leak is small, it could be possible.
However, what bugs me most is that I have no clue why it shouldn't work. Thinking hard, and disturbing my day job too.
I hate puzzles like this  ;D
Low-Q
What about replacing the tubes with flexible air ducts.
The membrane on these are very flexible, but will they shrink in length by applying pressure to the surface, or will they just try to squeeze together without getting shorter?
I want a design that is somewhat rigid in the diameter, but flexible in length.
Putting a plastic tube that fits nicely inside these, and the leakage and squeezing problem is solved for that part. The plastic tubes can be long enough to get through and some more, just like in the video.
Then use a much larger air duct to seal space between the discs. I'm not sure how the buoyancy will work if the water is trapped inside, and rotating with the tubes.
Vidar
ramset
Would be good if he could take some measurements around the clock/wheel
so  the displacement disparity and variables can be shown on paper
most likely a good Simulator could tell us the raw potential of this scenario
prior to losses
just for inspiration,
I absolutely believe it will show a gain...and if not ... maybe find solutions or??
a real brain twister with many possible considerations.
respectfully
Chet K
Thanks Grandma
