0 Members and 77 Guests are viewing this topic.
a.king21
Quote from: r2fpl on April 20, 2023, 02:02:57 AM
a.king21:
Huge capacitor ??? ??
is it the same capacitor? Is he really that big? What does big mean?
Tariel says there is a step down transformer with a capacitor to loop the device. If it was just a capacitor, there wouldn't be so many wires. It is exactly as seen in the photo.
You can even see the core of the transformer.
We need validated data to make progress.
Hairpin Tesla : is this the basis of the Kapanadze device?
Thanks for reminding me. Looks like I made a mistake. I'd still like to see his capacitor.
The basis of his device is what he says in the patent. He just left out some details. So no point in going off on a tangent of car mechanics or water/ hydraulic systems, - there is no patent to guide us.
But he has given us 2 patents. And that is what I am experimenting with.
They are still a guide.
So keep your eyes on the ball. Please.
fuzzb3k
Hi folks,
I'm not sure if this is relevant to the operation of the Kapanadze device, but I've noticed some similarities between various FE devices across history. They all appear to use capacitors to some extent, and I think the capacitor is the key to unlocking the common secret.
I recall Steven Marks saying:
QuoteIt is three separate coils of multi strand copper wire laid one on top of the other, not interleaved. Three is important. You can do many things with three coils. You can run them in parallel, you can run two in series and one in parallel, or etc.
EV Gray and Richard B. Hackenberger used capacitors charged with high voltage (2000V+) in their famous capacitor popping demo.
Imagine you have 5x 10uF capacitors in series charged to 10V. This gives a total capacitance of 2uF. Each individual capacitor is charged to 2V. Using Q = CV, we calculate that the capacitors are storing a total charge of 0.00002 coulombs.
Now, take these charged capacitors and re-arrange the circuit so that they are in parallel. This gives us a total capacitance of 50uF charged to 2V, which gives us a total charge of 0.0001 coulombs. This is 5x the number of coulombs than in the series arrangement.
The energy in each arrangement remains the same at 0.0001 joules.
It seems that switching from series to parallel is creating additional charge somehow, which in theory should 'amplify' current.
Where did the extra coulombs come from? Have I missed something obvious?
It appears to be converting volts to amps. Maybe this can be useful somehow.
I also found the following posts during my trawls through various threads and YouTube comments over the the year or so. They seem interesting and point to the capacitor as being a key element. I'm not sure who wrote them now, but I had squirreled them away in a text file for later reference.
QuoteI want to share something with you. T1000 and Nelson know well what I want to say. I previously wanted to tell on this site but some of you were opposed to what I said. And they wrote again and again that what I said was wrong. But what I said was true. No one has to believe my writing. But maybe it's useful for one of you.
The most important part of free energy is the capacitor. If you charge a capacitor with high voltage and high frequency and rectified with fast bridge diode has no resistance anymore and the cap charges instantly.  Then you get charge inside a cap and making that flow is amps.
If you load push & pulls at 50-60Hz per second and your cap charging circuit is doing 220-300kHz a second you got a lot of charge in the cap bank to pull into amps. I won't tell you exactly how to do this. But I will tell you the right way. The energy stored in a capacitor is a function of the voltage across it and the capacitance. Stepping up the voltage to any desired high value is very easy to do with the use of a high voltage module. Example is a flyback transformer. This means large amount of energy we can be created and stored inside a capacitor from any source of small input voltage and current.  And this energy directly into an inductor after each recharge.
When the LC tank circuit is in resonance the entirety of the capacitor energy is transferred to the inductor and stored in its magnetic field. This means the previous electric energy is now to magnetic and thereby yielding desired amperage. You should use for switching mechanism  such as transistor, high voltage power Mosfet,Thyristor..etc.
The most important is to match resonant frequency of the LC to guarantee at each cycle the energy gets fully transferred from the electric field of the capacitor C1 to the magnetic field of the inductor L1. Then released by L2 in the form of current out to the load and output capacitor C2.
QuoteYou can use Mazilli ZVS driver to drive an homemade 12V/100KV Transformer at RESONANCE and use 200pcs of 400V 100uf electrolytic capacitors connected in series to harvest the incoming RESONANCE driven Radiant Power.
The caps would be charged in series and discharged in Parallel using High Frequency Diodes connected to each terminal on the individual capacitor. The Anodes  of  diodes will be paralleled while the cathodes too connected in parallel to Mass up the Current in each cap of 400V 100uf. So in the end the Output power will reflect 400V 20000uf .
But the charging time will be low as the whole 200pcs of 100uf are in series which makes 100uf/200pcs= 0.5uf or 500nf.
When caps are linked in series, when being charged:
1. Charging current is the same for each cap
2. Charging frequency is maintained not divided as in caps that are connected or linked in parallel. So each cap sees the same charging frequency.
A TVS Diode or Varistor is needed to make a setup like this work and you can use extremely high frequencies like 1Mhz or more.
The Don Smith way of using Voltage Divider is not necessary Provided you have the money Custom -built High Power Inverter.
What you must keep to is Resonance.
The Mazilli Driver paves way for Auto-Resonance in the Primary so to make the Secondary rings, simply measure its inductance to get the needed capacitor to add in parallel to the output terminals of the Secondary High Voltage winding.
Remember at RESONANCE, OHMS LAW IS NOTHING PRACTICALLY!!
This is not a thought nor basic resonance. I have done a practical test and I can tell anyone authoritatively that you need DC caps to Harvest Radiant Power which is always massively Available at High Frequency and High Voltage applications.
Caps needs Voltage to produce Current thus the needed trick is to convert the hot voltage in the secondary winding of 12V 50 KV  Zero Voltage driven Transformer to Cold electricity by tuning it to Resonance  and thereafter convert it to Hot electricity using DC caps. But the problem is TIME taken to charge the cap in Parallel. So to counteract that, series connection of the caps is needed but the discharge would be in parallel via H.V Diodes like HER108.
Do not get it twisted, once Resonance is obtained you can set the Power for conversion and step-down number of ways.
Again do not get it twisted. The Caps connected in Series make one body but connected in parallel makes an individual body. 400V 100uf X 100pcs in Series is 40KV 1uf which makes 1 body. But 400V 100uf  X  100pcs in parallel makes an individual body of 400V 100uf when discharged via a Diode.
Charge time is what needs to be reduced.
You at RESONANCE charge in Series and Discharge in Parallel at 60hz via a High Voltage Fast Recovery Diode.
I have once told you that when Caps are linked in Series
1. Charging current from source is maintained
2. Charging Frequency is Maintained too
Those two basic principles make for overunity to be obtainable in this set-up.
The diodes connected to the positive and negative terminal of each capacitor are meant to sum up the Power of each caps in parallel. So the anode goes to the negative terminal of all caps in the array. While the cathode goes to the positive terminal of the caps in the array. Now connect all the ends of the anode in parallel and connect all the ends of the cathode in parallel too. There you have it now! You have to add up in parallel using diodes.
You need not to disconnect and reconnect anything. I assume you know how to do the switching going by your background in electronics.
We are pumping caps here so all we need to do is to Dam the overflow using a High Current Choke and "vastorised"  the unneeded excess voltage to ground. And from there to the final output DC Cap then to a High Wattage Inverter.
What my simple setup is about is to trick the Resonant energy from the Z.V.Switched 12/50KV+ Transformer into believing that the converting cap is of low capacitance in nano fares range. So it pumps it in a jiffy repeatedly and that will cause overflow when Diodes are used to harvest power from the caps into a Choke.
The High Voltage of say 40KV or 50 KV or more would be determined by the number of caps in series to achieve nanofarad range or lesser(picofarad)
The caps fill up in series in excess and you discharge in parallel at either 50hz or 60hz. So there will always be excess power available at an High rate.
The multifilar wire-wound secondary in the Z.V.Switched Inverter at first stage eliminate s  the need for second stage L1/L2 coil and also at RESONANCE negate Lenz effect before the series-parallel caps needed for Radiant energy conversion.
3rd coil or 4th coil etc. is not needed. Caps combined with inductor and varistor serve as a transformer before the inverting circuit. I know the actual direction you are moving but that I see will not be beneficial to other people reading my comments here. Anyways, goodluck.
a.king21
I was pointing out that the caps in the hairpin are a blocking device.
The current appears on the other side due to high frequency and high voltage which induces an equal and opposite charge on the other side of the caps through electrostatic induction
Obviously, you need HV and HF. The Don Smith reference was to show you a buy one, get one free situation.
If you look at the Kapanadze bare bones with that in mind what do you see?
That s why the cap is so important.
I also wonder about his transformers. Did we catch him out, or is it yet another distraction?
Sergh
Quote from: a.king21 on April 19, 2023, 02:31:50 PM
Take a look at the capacitor. It is pulsed from one side only by High frequency into an earth ground.
A capacitor is a blocking device. There is only one way that I know of that this can work.
The capacitor is not some mystical item.
The usual thing.
A long time ago, since the age of 12, I have been assembled, modifying and designing electronic devices in which I used various components, including capacitors.
With capacitors in childhood, I assembled various electronic devices, non-resonant, resonant, filters, low-frequency, high-frequency, power supplies, etc.
And he also charged capacitors from 220 volts, discharged with a screwdriver, sometimes on himself, disassembled, took out foil from them, overcharged and bursted, scaring friends, etc. There is no mysticism in capacitors. The resonant process in any resonant circuit always decays due to the dissipation of the energy of an external source loaded into the resonant circuit.
Just like the iron or kettle cools down after being turned off.
Quote from: a.king21 on April 20, 2023, 03:20:43 PM
Before buying a patent from lone inventors, it would be good for private investors to visit some large professional research center that professionally patents the results of their research and find out how much patents like Kapanadze's patents really cost.
I assume very few.
Patent some kind of circuit similar to the block diagram of an ordinary uninterruptible power supply?
The minimum description, which does not carry any specific information about either the real scheme or the process, there is no information in order to later win the case in court.
In addition, anyone else can apply for the same patent, replacing some details, for example, write that his device is different in that the bobbin is wound on a cotton core and this increases the output power by 100 times. Or that his device uses a coil instead of a bobbin, saving 100 tons of oxygen-free copper.
https://www.gizmochina.com/2019/02/01/elon-musk-tesla-patents/
Quote from: a.king21 on April 20, 2023, 03:15:05 PM
Remember it is not the electricity at the generating station that is powering your kettle. They are your own electrons bouncing up and down.
Thousands of gnomes spin a wheel with magnets at the power plant for food. This wheel with magnets creates a change in the electric field in the coils, which is transmitted through the wires to your house and pulls the electrons in your kettle. You pay the power plant boss to cook food for the gnomes.
Quote from: a.king21 on April 20, 2023, 03:15:05 PMThe biggest problem is that we have been looking at scopes and not magnetometers.
I suppose to wind a suitable coil and connect it to the input of the oscilloscope, to see the magnetic fields is not a big problem.
r2fpl
Kapanadze's patents are too general. One box contains 1-1000 elements.
Of course, the capacitor box is interesting, but only because it is labeled CAP. It seems to be very important in the whole system. However, we do not know what this capacitor is. We know that it gives a voltage to the oscillator circuit. It's really stupid if there's nothing else behind it.
Such a patent is very bad for investors. I have the patch notes for these patents, but nothing makes sense there.
Why do you believe that Kapanadze is the same as Don Smith?!? I heard they met at 100kW but is that true?
Why to this day no one has found even 1 watt in these devices. Kapanadze says that it can work on 200w but also on 200MW and everything depends on the coil, transistors and the rest. It really speaks beautifully.
a.king21: I have a lot of capacitors and I see only one interesting thing there; when it is discharged rapidly after a while it increases its energy but it is nothing but <1 The capacitor itself is very lossy if we count the power. It is better to keep the power as a magnetic field, e.g. in a transformer, because the losses are <5%
The capacitor works very well when it is in the LC system and when it is always charged then it is transparent.
.....The biggest problem is that we have been looking at scopes and not magnetometers.
yes, but the electrostatic field interferes with these readings and it's impossible to tell what we're seeing. Am I wrong and we see the truth?
