0 Members and 77 Guests are viewing this topic.
sm0ky2
Quote from: r2fpl on April 21, 2023, 09:51:08 AM
Some time ago I wondered if it was just electrolysis with an iron rod in the ground. It should be noted that Kapanadze dug a hole in the garden and placed the radiator from the car there. Then he flooded the entire area with water. In another video, we see him using the ground to a water pipe. Other locations are not shown except for one when the grounding is a building structure.
We must pay attention to one more very important detail: this is the current measured with a 24A clamp meter on the ground wire!!! How is this possible ? We know what the possibilities are and when you analyze all of them you will understand that the current is coming either from earth DC/DC pulse or AC.
Kapanadze copied this from an Earth Battery demo some guys in Africa made.
Was replicated again in Russia with both small radiators and several large ones, showing it can be scaled up and down.
TK showed Telluric currents on an oscilloscope many years ago
Demonstrating that there are DC, Pulsed DC, as well as several independent frequencies
flowing through the ground
He even went as far as identifying some of them (60hz, a few cable tv channels, local radio, etc)
Grid currents can be removed by moving further away from the residential earth ground
When it comes to showboaters:
It is important to understand the history of the mirages they promote.
r2fpl
Quote from: sm0ky2 on April 21, 2023, 11:27:38 AM
How to see Telluric currents on oscilloscope ?
a.king21
Quote from: r2fpl on April 21, 2023, 02:59:36 AM
a.king21: I have a lot of capacitors and I see only one interesting thing there; when it is discharged rapidly after a while it increases its energy but it is nothing but <1 The capacitor itself is very lossy if we count the power. It is better to keep the power as a magnetic field, e.g. in a transformer, because the losses are <5%
The capacitor works very well when it is in the LC system and when it is always charged then it is transparent.
.....The biggest problem is that we have been looking at scopes and not magnetometers.
yes, but the electrostatic field interferes with these readings and it's impossible to tell what we're seeing. Am I wrong and we see the truth?
You perhaps are missing the point as is everyone else.
Every single electronic interaction produces a magnetic field.
The magnetic field set up in a straight conductor carrying current is always at right angles to the direction of the flow of current.
At household levels, this is not that significant. As the frequency and voltage increases the results become exponential in our favour.
Every OU-claimed device that I have come across has this feature:-[size=78%] From Benitez right through to Kapanadze. There is a massive amount of magnetic energy outside the device at HV and HF that is not accounted for by Kirchof's or ohms law.
The capacitor:
Once again: at ordinary household levels its behavior is as per Spice.
When you get into higher frequencies and voltages the rules change. The static field becomes activated. The static field is outside and inside the device as is the magnetic field. Both the static field and the magnetic field influence electrons both inside and outside the device.
In Kapanadze's case, he discharges his capacitor through the load into earth ground.
In the case of the video link I showed you, the  capacitor is not being charged in the normal manner.
Only ONE PLATE of the capacitor receives a charge. This is impossible with low voltages and low frequencies in terms of useful results.
The cost of charging one plate of a capacitor is negligible. The environment then charges the other plate in an equal and opposite manner.
This is called electrostatic induction.
You then suddenly have a fully charged cap, by the environment, which could be an earth ground or an air grounding.
https://www.youtube.com/watch?v=tASY07r9AD0&list=PLmf6BEWAWzyTeshjqaZH76NuyTgBqMi5D
time one hour and six minutes in.
What you are missing is that very little power is used to charge the left plate of the flat plate capacitor. The right-hand side is free energy provided by the static energy forced onto the right side by electrostatic induction.
Now you suddenly have a fully charged cap.
Now, what Kapanadze does according to his 2 patents is to take some excess of the extra energy from L2 and put it back into L1.
L1 now has increased power, so L2 is also increased. This now creates a vortex, and the system would explode if not for the spark gap which you can see in my previously posted bare-bones Kapandze patent.
I hope this helps.
favour.
r2fpl
a.king21: Charging only one side of the capacitor requires one plus or minus sign. Depending on this sign, the earth gives or gives equalization of the charges in the capacitor.
The simple way is the Van der Graaf generator. Here you get only one character at the top. To get only + you have to separate the plus from the minus beforehand. It takes as much energy as connecting it to the ground!
I don't know of a cheaper method of producing only pluses.
I was wondering about this a few years ago. I was doing some static tests with discs and then I understood.
What you mention now is really beautiful and could explain how Kapanadze's devices work, but show me a cheap way to charge a capacitor with one side to ground. It's going to be easy ;)
Dom Smith shows us a trick and either doesn't understand what's going on himself or makes the audience look like idiots.
As I have shown, it has a connection to the ground on both sides. It is not even grounding 10m away, he just firmly connected the right side to the pin in the grounding socket.
Secondly, I did this experience. The plates carry the voltage in the form of plasma or thin discharges that we cannot see. It's another trick but not seeing the cause.
bmind23
Quote from: r2fpl on April 22, 2023, 02:25:42 AM
Proszę o przetłumaczenie mojego posta na język angielski.
Widzę, że do końca nikt nie rozumie o co chodziło Donowi Smithowi w doświadczeniu z dwoma metalowymi płytkami przedzielonymi izolatorem.
Chodziło tam mianowicie o ciągłe podwajanie początkowego ładunku elektrycznego. Co nie jest niczym nowym, już w 18 wieku ludzie to robili. Nie będę się rozpisywał jak to działa, wszystko jest wyjaśnione w załączniku. Antonio Queiroz na podstawie 18 wiecznych doświadczeń zbudował współczesne podwajacze ładunku. Pytanie jest takie czy jest możliwe zastąpić ruch posuwisto-zwrotny, który powoduje podwojanie ładunków współczesną elektroniką, by wyelminować ten ruch. Oczywiście musiałaby być inna konstrukcja podwajacza tworzącego 2 kondensatory o zmiennej pojemności.
