0 Members and 76 Guests are viewing this topic.
r2fpl
rakarskiy
LENZ in my opinion is the same as sawing a board. If there is no movement there is no LEZN, if there is no force on the board there is no LEZN and the board will not be sawn. So you can't saw a board if you don't saw it.
Of course, you can say that a board can be broken, but it will still resist.
Question; how to saw a board without touching the board with the saw?
Of course it's a stupid question because it's not the same as LENZ but just my interpretation. If you don't use tricks of thinking, the analogy is quite good.
rakarskiy
r2fpl
Look, let's accelerate the generator and measure the no-load EMF at the free phase ends.
The EMF is there (E), the magnetic flux is there (ϕ) and the time of flux change is also there (∆t):
E = - ϕ / ∆t
There is no current force and magnetic field around the conductor yet, but Lenz's rule is already satisfied.
r2fpl
Quote from: rakarskiy on July 01, 2023, 04:40:34 AM
r2fpl
E = - ϕ / ∆t
Correct. LEZN is always ready if the conditions are met. The interactions are small because the resistance is small, but they are there because the current flows in the conductor.
The same will be true of electrostatics.
When we don't care about LENZ? when we have energy. That's what I'm talking about. Kapanadze duplicates energy from electrons, or more precisely from photons.
r2fpl
raarskiy:
I see what you've been doing for a long time and I can learn a lot from you but tell me? did you ever get anything that could be called free energy more than 1W? In fact, my question should be more than 100W because 1W can be obtained from a lemon but that's not what I mean but if we have 10000 lemons it will also probably be 100W :)
Don't answer if you don't want to. I say this because, as I said, we do not know the mechanism for Kapanadze devices and we are trying to find something and adjust it.
rakarskiy
Quote from: r2fpl on July 01, 2023, 04:56:27 AM
raarskiy:
I see your point, the conversion process in a closed loop (self-propelled systems). Only in electromechanical and inertial accumulator-capacitor. Impulse mode. The problem is the difficulty of driving the flywheel, in those modes where its "kinetic power charge" is interesting.
https://www.youtube.com/watch?v=aDexsIqfA6M
An extreme project that I consulted, unfortunately the fate is not known, with the beginning of the barbaric war started by the orcs - who do not remember their kin against my radiant country. The only thing left was to make a system of interval power extraction from the generator. For such power it already revealed the problems of manufacturing the inverter.
