0 Members and 18 Guests are viewing this topic.
forest
I think there is slight connection between this topic and Figura discovery . Both need very strong Field. This is the secret which lies on fundiation of every ou
DreamThinkBuild
"How does the Tesla Transformer and associated, so called, Antenna helical coil interact with (influence) the Grenade Coil?"
Maybe there is a way to create a solid state flux/charge compression generator without the one shot energetic effect while minimizing the loss mechanisms.
Quote"An investigation aimed at optimizing the integration between a capacitor based prime power source and flux-trapping helical flux compression generator (FT-HFCG) is presented. An FT-HFCG simulation code, previously benchmarked with single and multi-pitch generators, was employed to study the kilo-joule class explosive system for this purpose. The details of this effort, which include the optimization of the field coil and stator coupling, as well as an examination of the effect of field coil parameters on the system performance, will be described in this document. For the simulated parameter space, the choice of field coil configuration caused the system energy gain to vary by 300%, and the optimum field coil configuration was found to be a single Litz wire conductor that had an axial length which was approximately 60% of the stator axial length."
source: https://www.semanticscholar.org/paper/Design-considerations-for-flux-trapping-helical-by-Young-Neuber/cce87fe5decead8c8ca43f35d785d378deb2ea32
Note: The zip file contains a pdf on flux compression generators it was 7k over the limit  ::) so I had to compress it.
Belfior
"Driving a conductive surface already containing a magnetic field" sounds like small antennas being driven with small power to make them appear electronically bigger.
Read this in one paper that described how to make small antennas appear bigger than they  physically appear
AlienGrey
Quote from: Belfior on August 25, 2018, 05:23:12 AM
Why would any one want to faff about with cultivating a magnetic field out side the ARadio field ???????
radio waves and magnetics < light speed  and Lenny baby's law :( :( :( :( :(
that's the difference in Radiant energy field.
AlienGrey
Quote from: DreamThinkBuild on August 24, 2018, 08:56:46 AM
try winding the thick wind the other way! and dump the mechanical switch  ;D
