Kapanadze and other FE discussion
Started by stivep, May 26, 2018, 01:48:55 PM
Sergh
Quote from: stivep on July 06, 2023, 10:37:21 AM
Few days later you  already forgot details
but I did spend  my time and money to make experiments , buy equipment and  make comment here.
;D
Working days, evenings. Not all about this is included.
...day xxx (not sure)
The syringes were replaced with a hydraulic cylinder. The hydraulic cylinder had to be disassembled after purchase, cleaned of conservation grease, cleaned of rust, lubricated with oil. Screwed on the handle. Not convenient, but creates a vacuum very well. Pure vacuum without oil aerosol. Another experiment went well with him. Hmm, there is a youtube video of office chairs exploding due to the compression of oil vapors with air in the lifting mechanism.  The principle of a diesel engine. What about with HHO?  :D Something I'm afraid of the hydraulic cylinder, but probably in vain, it works not for compression but for rarefaction and the concentration is still very low. Nothing will happen.  :-\
...day xxx+1
very successful, but the efficiency is low, not suitable for practical use. Needs to be improved.
...day xxx+3
The equipment has been improved, fresh zeolite is filled up. unsuccessfully, :(
...day xxx+4
The equipment has been improved. Control test without zeolite. Not bad.
...day xxx+5
a package arrived with an old induction RF generator, but without a power supply. I made a power supply, the generator works. But it is not suitable for the current experiment, because the discharge in the tube does not glow.  :( Strange. Set this generator aside for the time being.
...day xxx+7
Again with fresh zeolite, very bad,  >:( the reason is not clear.
...day xxx+8
I bought a couple of diaphragm pumps at a flea market. Hmm, they're probably from old oxygen concentrators, one smeared inside with zeolite. I hope there is no coronavirus inside. Cleaned everything up with spirit and replaced valves. The pumps working, but the vacuum is not enough for my experiments.  :( Put the pumps aside.
...day xxx+10
The equipment has been changed. Bad, absolutely nothing, :-X it is not clear why. Sensor test, 2 out of 3 are good. One, "new" from the store, incorrect output voltage, does not respond, has minor mechanical damage, so it is probably faulty.  :(
I looked for something new on the internet about Kapanadze, found a couple of video translations, just on the topic.
...day xxx+14
due to the increased power, the glass burns out, but I can't replicate what worked three weeks ago, searched the internet, nothing.  >:( Assumed maybe something practically useful will be written on the forum. As usual, nothing happens. Found about the crystals of Tbilisi. Interesting. Posted a link with auto-translation on the forum.
...day xxx+15
the glass insulator burned out again, the vacuum is not maintained.  :(
If only someone could post something useful on the forum. Nothing but squabbles.
re-read one important patent, there is probably another factor that could be the cause of the failures, I need to mount everything back and try.
...day xxx+16 (not sure)
Due to attempts to increase power and reduce the duration of the pulses, the transistors burned out, it's not a big problem, there are a lot of all sorts of mosfets in a box, but there aren't just such transistors, you have to go to the store.  :( All the time I want to sleep, on autopilot, more coffee. Wesley on the forum writes about the hard life. Could he write something on the topic? Memoirs about Kapanadze? Maybe it would increase the number of visitors.  :)
kolbacict
Quote from: Sergh on July 07, 2023, 05:14:18 AM
One of my acquaintances, also a fan of a perpetual motion machine, bought a Komovsky pump at the acceptance of scrap metal.  It was thrown out of the Soviet school.  Always dreamed of this.
Good thing.
Sergh
Quote from: kolbacict on July 07, 2023, 07:56:47 AM
Komovsky pump
Good thing.
Yes, maybe, but such a pump with oil filling. I already have a two-stage rotary vacuum pump with a motor. The problem is the oil aerosol at the exit. I installed a filter from the air compressor at the pump outlet, but some oil vapor passes through the filter.
kolbacict
And sound wave,especially ultrasonic is creating  zones high and low  pressure in gas.
Could this used ? In addition, it penetrates into any caverns of zeolites.
stivep
Here is  a  very simple patent application originally  posted in another forum by Forest.
Its simplicity  is  absolutely uncommon.
If I understood properly it was filed by child
with  big  help of parents to file patent application
Receiver device of energy from the earth and its atmosphere
https://patents.google.com/patent/US11588421B1/en#legalEvents
update:
I was shocked  with the simplicity of the design.
Why nobody come with that  before including me?
So at first look  few minutes at this video and I  explain the patent in my next comment.
https://youtu.be/2rVdEhyMR6A?t=26
Wesley
