IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?
Started by George1, July 21, 2018, 08:11:37 AM
George1
Any member of this forum who is a top expert in computer simulation of mechanical systems? As they do it in NASA and in Formula 1?
F6FLT
Quote from: George1 on October 06, 2018, 05:25:20 AM
...BARON MUNCHAUSEN CAN LIFT HIMSELF INTO THE AIR BY PULLING HIMSELF UP BY HIS OWN HAIR FOR SURE!
Does he use the same method as Peter Pan?
Low-Q
Quote from: George1 on August 26, 2018, 05:42:09 AM
I do not see any comments. No one here is interested in reactionless drive?
The point here is how one can pull his own hair and lift himself into the air. The hand that pulls, will pull equally in the opposite direction of the weight he want to lift. Such videos, or statements are untrue because it's a good trick, with nothing more to it.
Vidar
F6FLT
Quote from: Low-Q on November 05, 2018, 08:17:31 AM
...The hand that pulls, will pull equally in the opposite direction of the weight he want to lift. Such videos, or statements are untrue because it's a good trick, with nothing more to it.
I share your opinion, Vidar.
The configuration reduces to a closed mechanical system and no new physics is assumed. A Lagrangian can therefore describe the system, which excludes any possibility of non-conservation of the momentum.
I consider this thread to be a good joke, even if it is not the April fool's day.
George1
To F6FLT and to Low-Q.
Are you really ignorant or you only imitate ignorance because of the money you receive from the BIG OIL and/or from similar organizations? Most likely the second one is true.
