IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?
Started by George1, July 21, 2018, 08:11:37 AM
lltfdaniel1
68:16 But by this, THEIR KNOWLEDGE (science - 1 Tim. 5:20), THEY PERISH, and by this also its power consumes them.
twh 1:1 Thousands of earth years ago,far away,in this galaxy,on the morning star(venus),the Lord Guardian Of Divinity,King ruler and Guardian of the Universe,put down a revolution led by Lucifer(Iblis)
lltfdaniel1
Quote from: gyulasun on February 24, 2021, 10:58:49 AM
Hi Dan,
Yes the so called perpetual motion holder is a kind of electromagnet: you energize it with a current pulse and the core gets magnetized. However, how long it holds its magnetism depends strongly on the core material, how soft or hard iron it is made of.  You surely have heard of remanent magnetism of the different cores:  core remanence is the explanation for the perpetual motion holder.  If you suddenly pull the keeper apart, the enclosed (remanent) magnetism induces a higher singly pulse in the coil and vice versa.
Please have a look at this youtube channel https://www.youtube.com/user/Raselli1/videos  and watch the videos like  Transformer core tests part 1  and then part 2, you will understand this more.
Gyula
Thank you i will study that.
This phenomena is now explained much better for George here as well as me so without your input we would not know as you know better here anyways a link > https://www.electrical-engineering.academy/posts/the-secret-of-remanence (mind you it appears what led leedskalnin the inventor of the perpetual magnet holder it is a different electric wavelength when compared to the other wave length of this link here which is secret of remanence link.)
Seemingly magnet current right, well.. according to secret of remeance link no current is there but if you collapse all of it, current comes back out though (actual current to power a led spike until the field is gone_, i don't know but there seems to be a magnetic memory current flowing though.
However what the inventor says that the waveform is a double helix meaning it is different and i know full well you can get exceeding energy from it, because the double helix allows flow of energy to come in and out, unlike traditional electric wave forms which the understanding is more mostly based off.
Understand remanence is maybe one key to understand the overunity prospects of designs like the tpu and the like.
Those youtube videos experiment will help teach me also recommend others to watch, nicely educational for people to think outside of the box.
https://www.youtube.com/watch?v=qZV4-2pFI5M
The only thing i can see is the vital bit for free energy machines to work is regauging effect for the magic to work https://www.freeenergyplanet.biz/energy-from-vacuum/lorentz-regauging-of-the-maxwellheaviside-equations.html and http://www.cheniere.org/techpapers/jap/masterprinciple.htm
Every other technique known to man won't work unless it is regauging energy.
George1
To lltfdaniel1.
Hi Dan,
Very, very interesting posts! My respect to your ability for finding of such valuable pieces of non-standard technology information! I am starting reading your last posts immediately! And I will write to you in the nearest future!
Regards,
George1
Our simulation/animation is given below.
Firstly, please always keep in mind and please always refer to our first post of July 21, 2018, 02:11:37 PM and to the related two links
https://mypicxbg.files.wordpress.com/2018/04/pages_01-12.pdf
https://mypicxbg.files.wordpress.com/2018/05/figs01-08.pdf
Secondly, our simulation/animation presentation is subdivided into three consecutive separate parts for an easier understanding.
PART 1. Please look at the link https://youtu.be/9cBGurYSryw
1) The zigzag device and the straight-line device are put together vertically one to another and are fixed motionless to a horizontal motionless plane.
2) The two blue T-shaped components start free falling together and simultaneously. Friction is negligible.
3) In the straight-line case the T-shaped blue component falls freely without any interruptions and obstacles.
4) In the zigzag case however after the blue balls enter the zigzag channel the blue T-shaped component slows down its vertical downward motion and decreases its downward vertical velocity.
5) In one word, the straight-line modification blue T-shaped component covers the distance between the highest position and the lowest position much faster than the zigzag modification blue T-shaped component.
PART 2. Please look at the link https://youtu.be/aVOfWLDrYwA
1) How to slow down the vertical downward motion (that is, how to decrease the vertical downward velocity) of the straight-line modification blue T-shaped component?
2) The answer is simple. The straight-line segment "s" is made rough (inside the channels) as the related force of friction is chosen in such a manner so that in the lowest position the linear downward velocities of the two blue T-shaped components are one and same and equal one to another.
3) In one word, the zigzags generate mechanical resistance, (a) which is absolutely identical and equivalent to friction and (b) which does not generate heat.
PART 3. Please look at the link https://youtu.be/pPGPktU_kpo
The last link simply repeats the experiment, described in our first post of Sat Jul 28, 2018 12:41 pm and in the related two links
The zigzags generate again mechanical resistance, (a) which is absolutely identical and equivalent to friction and (b) which does not generate heat.
In one word, the text above and the related links above unambiguouly show that (a) either the law of conservation of linear momentum is not correct or (b) the law of conservation of mechanical energy is not correct or (c) both the law of conservation of linear momentum and the law of conservation of mechanical energy are not correct simultaneously.
Looking forward to your answer.
lltfdaniel1
