IS THIS A REACTIONLESS DRIVE OR A PERPETUAL MOTION MACHINE?
Started by George1, July 21, 2018, 08:11:37 AM
George1
To Floor.
I am not sure who is the cheat an fool here, you wiseacre! Why do you always avoid to
SIMPLY ANSWER THE TWO QUESTIONS BELOW! ARE YOU ILLITERATE?! HOW MANY THINGS TO REPEAT ONE AND SAME THING?!
YOUR MASTERS WILL BEAT YOU, BECAUSE YOU FAIL TO MANIPULATE SUCCESSFULLY THE AIDIENCE!
Consider carefully and thoroughly again (and many times, if necessary!) the link https://www.youtube.com/watch?v=xX14NK8GrDY
A key component for a proper understanding of the zigzag mechanical concept is the SIMPLE OBVIOUS FACT, that the zigzags generate a mechanical effect, (a) which is absolutely identical and equivalent to friction and (b) which does not generate heat. And this SIMPLE OBVIOUS FACT is clearly explained and described in PART 1 and in PART 2.
And now focus on PART 3 where:
Ma = 1 kg
Mb = 4 kg. (The value of Mb can be either increased or decreased as many times as you want.)
V1 = 1m/s = const
Ffr. = force of friction inside the zigzag channels = 0.0000001 N. (The latter can be further decreased as many times as you want.)
N = number of zigzags = 10. (The value of N can be either increased or decreased as many times as you want.)
Shapes of the zigzags = sinusoids. (The latter can replaced by any other curve patterns.)
QUESTION 1: V2 = ? (How many meters per second is V2 equal to?)
QUESTION 2: V3 = ? (How many meters per second is V3 equal to?)
SIMPLY ANSWER THE ABOVE TWO SIMPLE QUESTIONS!
LOOKING FORWARD TO YOUR TWO ANSWERS FOR THE 14TH TIME!
Floor
Quote from: Floor on August 08, 2021, 08:04:38 AM
To George1
It is more than evident for all honest members of good will of this forum, that you are simply a cheat and a fool, who rejects obvious physical reality!
       floor
George1
To Floor.
Ma = 1 kg
V1 = 1m/s = const
YOUR MASTERS WILL BEAT YOU, BECAUSE YOU FAIL TO MANIPULATE SUCCESSFULLY THE AIDIENCE! YOU HAVE TO RUN QUICKLY!:)
LOOKING FORWARD TO YOUR TWO ANSWERS FOR THE 15TH TIME!
Floor
   NO, it is not.
            floor
