what electricity REALLY is.
Started by nitinnun, September 07, 2008, 07:20:34 PM
nitinnun
i'm going to try this copper core.
i can do far better than this. but this should be in agreement with the "energy effects".
it is:
1 big copper loop.
1 smaller copper loop.
4 plastic bottle tops, to hold the copper loops apart.
1 CW coil (8 turns), wrapped around the big loop.
1 CCW coil (21 turns), wrapped around the big loop.
(both coils ONLY electrically touch graphite/small-loop)
1 graphite stick, bound by copper wire, to the small loop.
(graphite does NOT electrically touch big loop. only touches small loop)
1 wire, connecting the CW coil, to the graphite rod.
1  glass pan ($7), to hold the sand and saltwater.
(glass is made of sand. and sand is immune to saltwater corrosion)
(sand/saltwater, will touch loops and graphite)
the big copper loop, will be connected to the steel frame, by a wire.
the CCW coil, will be connected to the capacitor/multimeter/fan.
ashtweth_nihilisti
 what electricity REALLY is.?
suppressed and only able to be freed by open source collaboration
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
spacecowboy
Oddly everything spins CW and CCW all at once. Think of it like this, if you were in space looking down at earths pole which way is it spinning. Now imagine in space you move around to the other pole and look down, what do you see, the opposite spin. So there is really no such thing as a one way spin, its all about your perspective as to which way you want to call it, but it always spins in both directions CW and CCW at once. Only when comparing the spin to something else do we say its CW or CCW in relation to that. But that is only perspective.
marathonman
Electricity is a non compressible fluid like substance that is 1000 times smaller than the smallest atom and 32 times more dense than lead. it permeates everything and is in the space between atoms. the only way to bring it to out of it's dimension (Counter Space) is polarization as does every living thing on earth. our bodies when the seed is planted in the egg causes a chemical explosion thus polarization bringing in the power to divide as a woman's body does not have the power to do so.
all living things, us, birds, plants, animals all pull from this very thing we call Aether. all the greats of our past believed in this thus built everything we have.
all the ones that didn't,  didn't build a darn thing just bumped their gums with nothing to show for it but a title.
It's all about pressures of highs and lows in our universe. all generators are a pressure system as is every device that produces electricity.
regards,
Marathonman
