Aetheric transformer/inductor
Started by aether22, July 23, 2018, 09:06:04 PM
From quadratic transformer to round transformer to co-axial transformer to air core( transformer)                                                         To rectenna
aetheric transformer : Ranque- Hilsch tube.   cold/hot ambient.                             inductor        : Carbon Nano tube.       Electron tunneling
Did  the pioneers from the "Aether/Ether" defind it as " gas" or " radio-ocean(Dirac,Moray)/radiation/emissions" or bodies/Korpuskel ? The source ?
Was the first proclamation about " aether/ether" before or later the Physics acceptance and definition from
" radio-activity", alpha- beta- gamma-.....particles-rays and opto-electric bandwide in nm ?
Chain reaction and elementary decay and elementary enriching/pooring
elements classification tabella with/-out Isotopen
elements classification tabella with/-out ORMES ( mono/ di- atomic)
Make these for the "energy receiving and transforming devices" a difference ?Free Energy and Bonded Energy
Could the Pierre Chambrin "transmutator" giving partial answers , including the experiment and result from a Laboratory of the University Vienna related Homoeopathy "potenzieren/ verduennen": a Scharlatan-fake or physical core information transformation/transmutation , effect morphing, only detectable and proveable by electron-microscopy.
Infra-red waves/radiation by free emission has no temperature ( written in the astrofoil - foil bubble webpage)
Michael Rodrigues, GB inventor Club,  " temperature"- explanation view= oscillations/ turns/ pulses
Sincerely
aether22
Quote from: Tynoo on August 05, 2018, 05:26:48 AM
..direction of the coils !
The green conical winding diagram in the first image if I am interpreting the dot symbol correctly (never been totally clear on how to read that, as turn direction or some interpretation of relative phase) it is additive.
In the other images it looks that it is reverses in the outer turns and that would probably fit my scheme better.
Now there are a few things I would note, first is that a conical shape as shown will create a flow of aetheric energy due to the asymmetry.
The other is that colour DOES have an effect and while I do not know if colour insulation tape will have an effect on wire, and if it does will it have an effect on the level of energy needed for this, I don't know, but colour absolutely affects the aether, blue tends to accelerate energies, orange slows energies, a certain green will "make" energy and a purple colour will destroy or dematerialize energies, basically it all acts as a ramp, blue is a ramp towards faster /  orange is a ramp towards slower \  greed is a ramp that meets in the middle /\  and purple moves energies to both ends of the spectrum away from the middle \/  But you can do the same with sound, for instance if you create these shapes on an equalizer with white noise you can create these same effects, this has to do with energy chasing along the increased amplitude.
Green is basically the colour of energy materializing into this reality.
But, again this is not really just about green, this can be done over other spectrum ranges and in other energies.
There is a lot of green, and all that green helps materialize energy from the sun, and there is a lot of blue, that helps accelerate energy which if healthful.
So green and blue = good.
Orange and purple = bad.
Though it's not abut the isolated frequencies, but abut the spectral ramps that such a colour usually represents.
But, if I am coming to a point, it is this, you want to use blue coated wire or blue tape with a coil if you want energies to be accelerated...
Green if you want something to materialize.
And some orange might be ok for the part where you want power to manifest as this MIGHT help shift the energies to the physical.
If you look at Kapanadze and the early claims of successful replications the blue seemed to be ever present.
So, if you want to create a blue that accelerated on a computer screen, just have Blue 255 Green 80 Red 10   This creates a ramp, well, a lot of numbers create a ramp, but this is better than a blue just composed of blue pixels.   Printing uses a different proccess of Cyan Magenta Yellow and so this might not work so well in that colour-space.
aether22
The component labeled "Ferrit HM40" or something in that first image does match the requirements for my outer coil, it shows what appears to be counterwound coils in series with more turns one way that the other, creating what looks like a bucking pole in the middle.
aether22
I have just had an idea, and this might relate so designs such as those by those crazy Russians...
So, aetheric energy and electric energy both exist and both flow in wires, the amount of aetheric energy is highly varied by the source of electrical power and many other things.
But, just having both in the wire does not necessarily mean much, for the aetheric energy to become useful it must do one or more of 3 things, that is disintegrate the conventional energy till it becomes more aetheric, copy/mimic the conventional energy or meld with the conventional energy.
Broadly speaking one or some combo of those things (and, they might be more different view points on the same phenomena) happens when conventional energy in converted/manifested, the aetheric energy is transformed along with it and the 2 become in some manner mixed, once mixed Free Energy might not just happen, but with such electro-aetheric energy making OU would be as the resultant energy can be used to do all manner of extraordinary things, including asymmetric induction which will give OU.
So, how do we "proccess' such energy you should then ask?  Well, you want something that will recycle the energy again and again back and fourth, again and again.
One excellent way is with a motor/generator, indeed if it is driven independently, you can setup a situation that just shuttles energy between the stator coils and the rotor back and fourth with no real drag and no real drive...
Ideally you want more than just say a tank circuit...
And that is when I had an idea!!!  And those Russians have some something like it.
What you do is instead of having a rotor which a stator coil helps and accelerates during part of the cycle and hinders during the other half, why not a high frequency tank circuit inductor, and it can induce energy into an adjacent loose coupled coil.
High freq tank   <>   Coil with DC or lower frequency
When the HF tanks inductive voltage adds to the voltage in the low or no freq coil, it shuttles energy to the coil, but when it subtracts it steals energy from the coil, it does this potentially hundreds or thousands or millions of times a second.
The induction of the tank ads and removes energy from the coil at a high frequency, the higher the frequency (without inducing high losses due to skin effect etc) the faster energy is induced and the faster energy is processed between the 2 coils.
So this makes a lot of sense to me.  so, what is the ground about?
Well, aetheric energy is limited in a lot of sources, but correctly stimulated, the earth has a lot of aetheric energy, this could be the source of the aetheric energy, at least part of it.
I still need to test that this works, I have been trying to find east to implement yet effective ways of moving energy between components for a long time and this seems particularly perfect, a signal generator plus and amplifier to induce energy into the tank circuit, easy enough.
The DC coil might as well be air core, at least the end exposed to the HF part, it might be a good idea is the other end had a fair bit of impedance, this will inhibit the LF coil from sucking the HF tanks energy.
Tynoo
Very good ideas ...and explanations!
The  coils images (grenade),create disturbance in the environment,(very small the working window)
when the tuning starts to make it smells like ozone !!
But the resonance is very complicated.I concluded that there are many other secrets (ex wire colors).
I use yoke TV,or 3,small and large to increase core.
With OFC colis (oxygen free copper) the yield is more high.
I started with the engines, start resonate is wonderful to an ordinary electrician or electronics.
But I gave up because it has moving parts and makes noise,I'm going to make a video of the bigger one and rotate it slowly for you to hear,when it starts to produce energy (only pure iron)!!!
Electronic circuits are easier to make and control.
The color green and blue I will test in practice.I'm using multiple frequencies from 10 to 10,000Khz.
I got many granades built.
