Free Energy is IMPOSSIBLE without this, why everyone fails!
Started by aether22, July 24, 2018, 12:32:48 AM
aether22
Quote from: marathonman on July 26, 2018, 10:45:38 PM
Me: you have absolutely no clue what so ever as to the truth.
Me; the electricity is the Aether pulled from counter space dimension caused by the polarization of the primaries.
We will have to agree to disagree.
But it is worth noting that electricity, the movement of charges, these charges are already in matter in this dimension.
What you are saying is true only of the aetheric component of electricity, and the aetheric component can be stripped and the thing called electricity still occurs.
I am not saying that EMF's don't maybe pull aetheric energies which might have a pseudo or fractional electrical charge from a couterspace dimension, not that I would say it does, but I don't know what a "counter-space dimension" is in the first place.
Certainly electron and proton like energies are moved by such a generator, and these might be described as extra-dimensional or something similar.
You; "That's not really true the thing you refer to as a generator doesn't generate any thing it's a contradiction in terms."
I did not say that, another poster did.
who said anything about generating but you. it is YOU who is wrong and stop putting words in other people mouths and read what they say not what you thought they said. it is you that does not know how a standard generator works. they are Aetheric pressure systems all day long.
You; "Generators are MOSTLY explained correctly by convention, by Lenz Law."
Me; WRONG again and not even close. living in a fantasy land explained with incorrect assumptions.
You; "it is a flow of valence electrons (or ions outside of metal)"
Me; Completely wrong again. typical Dogma taught College School BS grasping for straws handed down from generation to generation.
You; "Fact is, conventional physics accurately and almost completely explains most things to very high degrees of accuracy"
Me; OMG !  i can't stop laughing, that is like watching Feynman explaining a magnetic field and squirming on a hot pan.
They have HUGE holes in their understnading, and there are whole areas of physics held together by sellotape and faith in Einstein.
But they also get a lot of things right, and there is a ton of evidence for electrons and a lot of details about it, there are maybe some funny things about spin and there are a few issues, but there is a lot that they get right and get right to amazing degrees, I don't throw out all of conventional physics, I just throw out portions that are obviously and proven false.  But each to their own.
"Faraday's law of induction is a basic law of electromagnetism predicting how a magnetic field will interact with an electric circuit to produce an electromotive force (EMF)—a phenomenon called electromagnetic induction."
WOW ! now i never would of thought of that if you were not here. thank you so much and thank you for sharing.
Not much learned here but very comical though. needs a few more years to ripen.
Regards,
Marathonman
IMO you are conflating 2 things.
The hadcore materialistic electrcicity which shows few if any signs of overunity or anomaly.
And the aetheric component which might be what you say it is.
The aetheric component can be huge for certain type of electrical energy generation, and this is the energy that can easily be turned into more and more energy with suitable processing.
aether22
Quote from: TinselKoala on July 27, 2018, 01:28:47 AM
Your quote /quote tags need some work.
Ah crap, something about this adds all sorts of font junk I have to clean up as well, just cleaned up my reply to you, ok, note to self, I should NOT intersperse replies here.
NOTE: FIXED
marathonman
I'll agree on that one.
all of man's electric machines are of electrical pressure (pressure systems)
Regards.
Marathonman
forest
I remember I read something about this topic  There was discussion in early 1900 about aetheric force and the consensus was established  that there is only one electricity , whih means all so called aetheric effects or even metaphysic effects can be finally explained by science. I believe it so that aetheric effects are simply electromagnetic effects here the sourc of power is our Earth not tthe circuit power source.
