Self Powered Generators&Motors-Part 8
Started by seraphis, October 10, 2018, 04:04:15 PM
seraphis
Publication Number
US2016-0094157
Title
ELECTRIC GENERATOR
Abstract
An electric generator comprises a substantially flat magnet having a series of alternating north and south polarities, the
magnet having an upper surface, a lower surface and opposing edges.A first metal plate formed on the upper surface of
the magnet, and a second metal plate formed on the lower surface of the magnet. A pair of wires is connected to one of
the first or second metal plates and an edge of the magnet, the pair of wires capturing for use energy or power produced
by the electric generator.
Field And Background Of The Invention
[0002] This is invention relates to an electric generator. More particularly, the invention relates to an electric generator
which utilizes magnets which are sandwiched by one or  more selected layers of metals. The configuration and construction
of the electric generator of the invention may produce a flow of mass particles, which can be controlled and
harnessed, and whereby a charge flow is setup within the system which can be utilized for the extraction of power or
energy to form the electric generator of the invention.
Summary Of The Invention
[0003] According to one aspect of the invention, there is provided an electric generator comprising: a substantially flat
magnet having a series of alternating north and south polarities, the magnet having an upper surface, a lower surface and
opposing edges; a first metal plate formed on the upper surface of the magnet; a second metal plate formed on the lower
surface of the magnet; and a pair of wires connected to one of the first or second metal plates and an edge of the magnet, the
pair of wires capturing for use energy or power produced by the electric generator.
[0004] Preferably, the first metal plate is comprised of aluminum foil, and the second metal plate is comprised of aluminum foil.
[0005] An additional metal plate may be mounted over either of the first or second metal plates. The additional metal plate
may be comprised of copper.
[0006] In one embodiment, the magnet comprises a series portions of alternating north and south polarities. One of the
pair of wires may be connected to the first metal plate and the other of the pair of wires may be connected to a metal rod
extending from an edge of the magnet.
[0007] Additionally, a diode may be provided in the wire extending from an edge of the magnet. A plurality of such
electric generators are connected to each other, either in series, in parallel, or a combination thereof.
[0008] In one embodiment, the thickness of the magnet is approximately 15/256 inches. Further, the magnet may have
dimensions which are approximately 1" x 1" x 0.11".......
Brief Description Of The Drawings
[0038] In the drawings:
[0039] FIG.1 is a schematic view of an electric generator component in accordance with one aspect of the invention;
and
[0040] FIG. 2 is a schematic representation of four such electric generators hooked together in series and in parallel
respectively.
Alejandro
Do not know how much you can help me get this information because I want to access a lot of information, do not know how to help me?
seraphis
Here is the link to Patent - copy and paste into web browser search
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=2016094157A1&KC=A1&FT=D&ND=3&date=20160331&DB=EPODOC&locale=en_EP
Download copies of any Cited and Citing documents as well.
Also take note of Patent Classification and then do a search using same.
