The book is dedicated to self-propelled mechanical generating devices.
Started by rakarskiy, November 02, 2018, 11:56:37 AM
No,  I do not want to surprise you but only recycle the known information and development results which will become part of our technical future.
Elon Musk,  native South-African,  did not constitued Tesla Motors!
He later participated by this existent company as investor and became " awarded"( for the investment compensation ) as CEO.
And the use from such a " heavy over-powered electric engine", like the other so called " Premium Class Cars" do,
is from technical view stupid,especially by velocity regulated transit: 120-130 Km per hour max. !
My " Fun Car Class" https://www.greencarcongress.com/2005/04/reva_introduces.html
                                             37 "KW AC" /220 N*m peak
Test-drive : 12 KWh average in,  3 KWh recuperation = 9 KWh net/100 Km
"Es juckt mich ": drop away the 37 KW AC drive and install instead
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20001020&CC=FR&NR=2792258A1&KC=A1#
Included : 4 x electric net zero energy motor
and https://www.interpatent.de/    Electricity from the suspension ( for the heater / winter)
Cheap and appropriate :
https://forkenswift.com/electric-car-conversion-cost.htm
"Karl Luther" and his development is for me unknown !
Have a nice weekend
OCWL
p.s. : https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20001207&CC=DE&NR=10011074A1&KC=A1#
independent from the power source, for example instead "alleged" motor-generator a battery-set and inverter :
                             [0001]  a conventional nominal 1,5 KW /4000 RPM as e-drive  ( for urban cars)
                           Small is beautyfull            https://m.youtube.com/watch?v=1QW1-q3NklE        https://m.youtube.com/watch?v=ZGiviT-C_oY
http://www.engineair.com.au/index.php?option=com_content&view=article&id=18&Itemid=12                                      "    up to 100 times less energy  "                            also as compressed air/ electric motor hybrid
https://launchforth.io/dsm123/meteor-electric-hybrid-car-with-di-pietro-motor-rotary-air-engine-with-compressed-air/overview/
p. s.  II : https://www.sciencedirect.com/topics/engineering/air-cycle              related is the Jacques Boone rotative heat pump,  it is not based by cavitation
rakarskiy
Good weekend! I make thoughts around the clock, here I have no days off!
Your post, about the magnetic flux.
Quote from: lancaIV on December 17, 2005, 07:20:43 PM
Probably a help:
The first point:Prof. Ehrenhaft and his magnetic current explaination.
The second:we ,the humans,can not remark free U/IR-Radiation,
a radiation without temperature !
But when this radiation has not temperature ergo this radiation has(would) not (have) movement!
(Maxwell/Boltzmann)
Which is the source ?
In my book, I directly point out the heterogeneity of magnetic and electric play. Primary MAGNETIC FIELD. And the poles of Magnit are points of contact with other dimensions.
To create a device we don't need to drive to other dimensions. It is enough to properly use what is in sight.
The book. A-Generator, 1st Free Energy Generator.
                                  Referring 2005 posted info :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19690218&CC=US&NR=3428867A&KC=A#
  What he ,Ramos Suarez, described about the output and the "restriction" of use ? ( what wrote Bedini about "radiant energy" ?)
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=10&ND=3&adjacent=true&locale=en_EP&FT=D&date=20070201&CC=ES&NR=2265253A1&KC=A1#
Only for battery charging,  by actual high KWh battery prices this  kind of devices are not the solution.Probably later for electric car battery-/capacitor bank loading.
Also Dr. Pavel Imris flip-flop battery bank cycle has the actual " battery KWh price" malus :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=20180125&CC=DE&NR=102016008893A1&KC=A1#
I am not in the search and development of 10 or 5 Eurocent per KWh generators.
The target is the for the industrial process ready " 1 Euro-cent/KWh" and " 250 Euros/ KW" energy converting device with pure DC or pure AC.
rakarskiy
I have no goal at all, to adapt to the energy standards of the bad guys. The goal is a personal energy, excluding counters the bad guys. A device that will provide energy to the household. My dream is already there, a simple repeatable device.
Circuit as it should be, using the household's usual electrical circuit.
Personal Electric
kampen
Dear Rakarsky,
Just curious, did You ever build a working "Electro Magnetic Selfpropelled Generator" ?
Or You are just selling circuits?
Let me know.
Alex
