The book is dedicated to self-propelled mechanical generating devices.
Started by rakarskiy, November 02, 2018, 11:56:37 AM
stivep
Quote from: rakarskiy on November 27, 2020, 12:59:12 PM
Wesley  :D
You cannot, by definition, order me! In general, you should be glad that I respond to trolling.
In closed systems, efficiency cannot be more than one by definition.
Considering my self-contained hydrogenerator.
All power generated by the generator cannot exceed 5 kW (for example), but the efficiency is taken as a unit. The pump electric motor consumes 1.5 kW (5-1.5 = 3.5 kW to the consumer).
The efficiency of the installation can be estimated as 3.5 / 5 = 0.7.
But at the same time, the generation process is closed and self-propelled.
https://rakatskiy.blogspot.com/2020/11/autonomous-hydro-power-plant-for-home.html
At first:
- I didn't order you to answer It was very gentle and pleasant and respectful form of my interaction with you.
- I'm not a troll and I didn't troll you.( there is no money or value making me to do so)
___________________________________________________
Again your answer is not the answer in listed by me format.
If you have problems to understand English I will translate it  into Russian.
This is USA and Western World my dear  friend from Russia or Russian influence/ language  region.
If you have wrong  a key you will not open American nor European door.
We have money and  we can buy millions of your  books or just give you money for free because we like you.
Plenty of old Americans  donates millions of dollars for cats and dogs shelters.
BUT YOU NEED TO COMMUNICATE WITH US IN THE LANGUAGE WE CAN UNDERSTAND.
And use the right key to open our harts to your Russian/ former Russian values, needs, or  inventions.
Wesley
rakarskiy
Quote from: stivep on November 27, 2020, 01:24:47 PM
Wesley
Wesley, and who are you when you ask illiterate questions? The term energy is very slippery, engineers do not use it, only the world-eaters to account for commercial interest.  The engineer is interested in the moment in which the moment of energy is measured, and what its structure is.  When you answer, then you'll know what I mean
QuoteEnergy (other-Greek. ἐνέργεια-action, activity, force, power) is a scalar physical quantity that is a single measure of various forms of motion and interaction of matter, a measure of the transition of the movement of matter from one form to another. The introduction of the concept of energy is convenient because if a physical system is closed, its energy is stored in this system for the time during which the system will be closed. This statement is called the law of conservation of energy.
From a fundamental point of view, energy is one of three (along with momentum and angular momentum) additive integrals of motion (that is, time-conserved quantities), associated, according to Noether's theorem, with the homogeneity of time, that is, the independence of the laws describing motion from time.
The word "energy" was introduced by Aristotle in the treatise "Physics", but there it denoted human activity.
stivep
It looks like you have problem to understand English.
I didn't ask you what is energy.
An average teacher  of Russian/Ukrainian  High School for kids over 17 years old explains energy to students.
Please give me an answer in given format taking  the same or similar explanation  .
I will kindly ask you the same questions inRussian or Ukrainian
to make sure that you can understand  what I'm asking you for:
The format of  an answer should look like:
Answer to ad a:
the original form of energy used is: ( provide your explanation)
answer to ad b: original energy (described in point "a") is converted to : ( provide your explanation - list all of forms of that converted  energy)
answer to ad c: the  efficiency of the device  described by me is :( provide your explanation)
and efficiency of  the device described by me is more than 1 because : ( provide your explanation)
Формат ответа должен выглядеть так:
«Ответ на вопрос» a :
Какая первоначальная форма энергии используется в вашем устройстве: (предоставьте свое объяснение)
_________________
ответ на ad b
исходная энергия (описанная в пункте 'a') преобразуется в (предоставьте свое объяснение
перечислите все формы этой преобразованной энергии)
________________
ответ на ad c
эффективность( efficiency)  описанного мной устройства составляет (предоставьте свое объяснение),
а эффективность описанного мной устройства больше 1, потому что (предоставьте свое объяснение)
you can provide your answer in Russian /Ukrainian  or English
I understand all 27 Slavic languages and I speak 3 of them fluent.
Wesley
Floor
Wesley  :D
The device shown in the video t this link, is a Lead acid battery powered system.  The unit contains an off the shelf DC to AC converter.  Why it uses any water, I don't know.
   floor
rakarskiy
Quote from: Floor on November 27, 2020, 07:31:06 PM
   floor
It is better to clarify this in the primary source. Everything is indicated in the annotation to the patent. And most importantly, I only position devices for the home, where self-propelled sources of electricity work, to charge the intermediate battery. And only then through the inverter into consumption. Practice shows that for a house two batteries are enough for all needs.
It may well be that my solution to a simple hydraulic booster is not used by the Canadians, but there is another solution. It's just easier than I thought, impossible to come up with. And since I'm sure I'm not the first
all constructors cannot avoid this decision. I think the Canadians and Hardy need such a technique (a simple hydraulic reducer).
