How does overunity 'suppression' work if everyone knows about it ?
Started by postingsite, November 16, 2018, 08:50:25 PM
sparkmen
Quote from: lancaIV on January 04, 2019, 06:59:59 AM
On Planet Earth is a permant energy producing 50Watt device in power per annum aequivalent with a 1 sqm- local 1400 KWh solar radiation and 30% efficiency- solar cell module panel !50 Watt x 8766 hours = 438,3 KWh
1400 KWh x 0,3 = 420 KWh + 70 KWh in winter 1 sqm mirror-foil = 490 KWh-------------------------------What can you do with 490 KWh per annum ?Mister Chalko from the mtbest- organisation ( no URL wished, no URL delivering !) recom(m)ends:0,8 KWh electric x 365 days = 292 KWh " intelligent use" from electric sources  !
hi lanca, always wanted to buy solar pannels that work in the dark hours, to put some in my cellar, can you provide a link ? :)
sparkman, using for the bulbs performance Victor Arestov circuit or now v8karlo offered solution :
https://worldwide.espacenet.com/data/publicationDetails/biblio?DB=EPODOC&II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900201&CC=DE&NR=3817730A1&KC=A1
translated
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3817730&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Paul++marzahn&IN=&CPC=&IC=&Submit=Search
Their priority date and now 2019  !
The solar cell bandwith performance and efficiency since there !
But let me give an example :
for conventional thick silicium based cell modules there is given the performance with (900 full hours )180 KWhx 30 years by 15% conversion efficiency and 1 sqm solar surface area !
Let working them perpetuum= 24/365 to this 900x30= 5400 KWh means shortering their life time life to +- 3 years ex(s)pectance. 8766 hours( year)/" 900 full hours" ~ Quotient :10
Marzahn : 5x solarcell + 5 x foil mirror a 70 Wattp = 650 Wp - 156 Wp ( 13 x 12W CFL consume) = +- 500 W
Baquero Menendez : 8 panels a 240 Wp - 500 W emission bulb;
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20100615&CC=ES&NR=2341161A1&KC=A1#
"errare humanum est" : K is not cd= candela but means KELVIN,
what does differ lx= lux from lm= lumen physically and which metrical distance emitter/receptor
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=13&ND=3&adjacent=true&locale=en_EP&FT=D&date=20120322&CC=DE&NR=102010035706A1&KC=A1#
        This are simple - trial/ error- experiment descriptions
         CONDITIONING RULES OUR ALGORYTHM WORLD
You heared or reed about Heinrich Kunel his DC/AC " motionfree generator" and could remark the number of coils :so called "Ampere coils",with " physical coil turns" and in electrical process drived by " electronical Ampere- turns":
        Inverter
a. https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=19940318&CC=FR&NR=2695768A3&KC=A3#
A cascade coil-couple-series-system with many stages, 1.  bicycle- dynamo stage sufficient for experiment ( not active refrigeration need)
Here translated: http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=FR&ENGINE=google&FORMAT=docdb&KIND=A3&LOCALE=en_EP&NUMBER=2695768&OPS=ops.epo.org/3.2&SRCLANG=fr&TRGLANG=en
                                                    NO CAPACITOR,NO DI-/TRI-ODE                          bimetall,magnetostriction,electret(permanent e-magnet/ permanent m- magnet)  b.           http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=JP&ENGINE=google&FORMAT=docdb&KIND=A&LOCALE=en_EP&NUMBER=2007028879&OPS=ops.epo.org/3.2&SRCLANG=ja&TRGLANG=en
                 Kunel 10 coils/ Uchiyama 10 coils.
                         iron core/ air core
sparkmen
hi lanca, just refered to above calculation 8766hrs/365 days =24hrs /day working time .
unless pannel if fitted on Earth orbit , continuolsly exposed to  sunlight, it only makes a good product sales advertising..
so , does not work in my basement :(
Do you know what " Kitzler" bodybiological means ? EROS,  erogene Zone : Venus-Huegel
L.A.S.E.R. AND M.A.S.E.R. the "S." ?
How many "Orbit"-s are in use [ Roma: urbi(Urbs) et orbi] excluding, in Astro- and Quantumphysics ?
EMP= Pc+ Pi
Pi-Orbit : probably Yul  Brown relationship !?  ::) https://en.m.wikipedia.org/wiki/Oxyhydrogen
Historie: lux, Nom.( lumen,  Akku.)
                electricity
                electron gas ( Schroedinger)
                international convention : electron changed to : ion
                ion gas or Plasma     https://en.m.wikipedia.org/wiki/Ion
                Photo-voltaic( eV,  nm) and Phono-Voltaic(dB, eV)
Basement now?  I thought you wrote about " cellar" = Keller/cave !But , yes, also under your tect to fix, if you are in a tiny house and want 24/365 electricity/ Plasma generation !
https://en.m.wikipedia.org/wiki/Sunlight
https://en.m.wikipedia.org/wiki/Electromagnetic_spectrum
                                               NOT A NEED, but only to show Lab-Prototype Standart
https://www.extremetech.com/extreme/252295-layered-solar-cell-can-capture-wavelengths-solar-spectrum
             +   24/365 ARTIFICIAL/VIRTUAL SUNLIGHT :   Terrarium and Solarium of nano-organism
            8)   Quantumspace-Bordell + Kita  :-[ ( oh die Feministinnen  :o::););D
                                       micro-organism, nutrient,......  animalisch
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=7&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931111&CC=DE&NR=4222678A1&KC=A1#
A C2-Patent,  dpma-peers approved and granted !  DIRAC-SEA-MONKEYS
                                 Astro: cannibalistic( cogito ergo : Koppulation?) Galaxis
::) fresh new :  https://www.n-tv.de/wissen/Der-Milchstrasse-droht-ein-Crash-article20798395.html
https://translate.google.com/translate?hl=de&sl=de&tl=en&u=https%3A%2F%2Fwww.n-tv.de%2Fwissen%2FDer-Milchstrasse-droht-ein-Crash-article20798395.html
                  TWO  :) BILLION :o YEARS  :-\ IS  8)??? SHORT  ;D TIME >:(
        A " crash" prophecy  :P :  I will sell all my "MilkyWay"-shares !
Belfior
Quote from: sparkmen on January 07, 2019, 05:49:17 AM
There are also other affecting things. Like a panel too North of a certain latitude will not produce enough energy in its lifetime to make up for the production costs and pollution.
https://www.altenergymag.com/article/2005/08/solar-energy-potential-at-different-latitudes/120/
Yet governments give you tax benefits if you install them for example in Canada. You are basically just polluting then, because you cannot get the energy out of the panel that Chinese used to make it
