Gravity assisted pulse motor generator
Started by burnit0017, November 21, 2018, 03:56:58 AM
shylo
Hi Go Vertical,
Your fabrication skills always impress me ,nice work.
Have you ever built a big heavy flywheel mounted horizontally , mount a pma to it,
Make it so it is weighted heavy at one point on it's circumference.
That heavy weight is a big magnet, the flywheel has to be able to pivot, a gimble joint.
Use the output to fire your electro-magnet to push the wheel.
Your pma can't have any steel in it , look at it like three in one , instead of one set of coils all adding together.
Carry on artv
burnit0017
Hi, thanks for the suggestion.
https://youtu.be/nuBikcqf_Q8
I have to increase the capacitance at the delay capacitor bank so the Neo can travel pass the midpoint of the electromagnet before turning on.
At this time it is fighting itself because the electromagnet is turning on to soon. Thank again.
burnit0017
https://youtu.be/4J0SM_B1OZI
waiting for parts, built a more vertical two stage oscillator for testing
burnit0017
https://youtu.be/YR6LRujWDEQ
to many problems using a pendulum, rebuilding earlier configuration using a pulse motor
