Inarticulate minds stuck in convolution
Started by Mr.Miyagi, December 23, 2018, 03:58:29 AM
Mr.Miyagi
Brad is not even measuring Input current - he is measuring stray currents to ground, if his FG is grounded, and stray currents to feed his output, but not his output current.
What is wrong with you, why is no one pointing out these major errors?
Brad says, give me your over unity machine and I will measure it and determine if it is real or not, because you can't - he is a loud mouth that cant even get a few simple ac waveforms measured!
Mr.Miyagi
If you want to learn something, look at the capacitive coupling between brads coils, look at the direction of the currents, if brad had his input measured correctly, and then one could actually come up with a rough estimate of the value on his Capacitor.
Yes, Brad has a capacitor. A complicated capacitor. An example of displacement current and how theory states it may work could be seen to some small degree.
Mr.Miyagi
Brad claims his capacitor is some 300% efficient - I think his education is at question.
Mr.Miyagi
There you go, member Void has actually just said the same thing.
I suggest member brad keep his arrogant un-controlled mouth padlocked and start learning valuable straight forward basic things!
Dammed fool!
Mr.Miyagi
This incident will be going in my book!
A book about the personalities here that bullied and arranged for the banning of the brilliant mind of Chris Sykes, banned from this forum, so went and started his own to share working technology, the working technology I have seen first hand, been lucky enough to see up close. Other members also having working technology all based on the same work. Chris is the only person throughout history that has had independent replications of his work, including a short lived machine by brad, our resident loud mouth. Brad also assisted in the banning of Chris, making a visible effort to discredit Chris.
Chris's forum: http://www.aboveunity.com, which must be noted, he had the domain purchased months before the banning here, as if he had predicted the result, will not tolerate loud mouths like member brad. Their no trolls aloud policy is hugely successful, and the reason other members are making such wonderful progress. I am already a member there and I think I will be making this post my last here.
So, I suggest, if you don't wish to be stuck in circles, going no-where, with the same no-where people, the ones that have led you down rabbit holes for decades, if you want to make progress, if you want to follow some simple instructions, then make your way over and join the large community of like minded people, learn how to pump charged particles to power your load.
