Simplest real free energy gravity generator.
Started by stevensrd1, January 16, 2019, 12:13:00 AM
stevensrd1
This is the simplest real free energy gravity generator. Allow me to explain. Its all about the ram pumps, if you dont know what they are then do a search on youtube or google. This was known about back in the day but somehow was forgotten, wonder how that happened. Anyway a ram pump works like this. Water from a reservoir flowing down hill a little ways then goes to a ram pump. The ram pump uses that little water pressure from the down hill flow and then pushes water up hill to a great distance far higher then your reservoir. And it does it all mechanically with no needed power source of any kind since a ram pump is powered by gravity itself. Now you can take many ram pumps that get their water from one reservoir and have them working all at once pushing water up hill, this way you get a lot of water going up hill fast. Then you allow that water to fall down hill through electric turbines that generate electricity just like how hydroelectricity is made. And you direct that water that is now falling down hill back into the same reservoir that you used to get the water from in the first place. That keeps it full of water, and you have free electricity generated in the process of it all. So yeah totally free electricity can easily be made. And this was known about long ago, just some how mysteriously forgotten, misplaced, and turned into hydroelectric dams of today that supply the power most pay for. Just the real truth here people, believe it or not as they say.
F6FLT
The flow you can raise is always less than the flow that provides the energy, so the system cannot be looped.
It's like a transformer, just because you have a small voltage in primary and a large one in secondary doesn't mean you can supply the former with the latter. Always the same confusion between potential (voltage or water level) and energy!
citfta
Thank you stevensrd1 for posting the same thing in five different places on this forum.  You have made sure that everyone knows you don't have a clue about how the ram pump works.  As F6FLT has posted, these pumps are very inefficient.  If I recall correctly they only are able to pump about 1/10 of the volume of water that passes through them.  The rest continues on down the hill.  So it is not possible to use them in the way you describe.  Perhaps some research in the way they actually work would help you understand what the ram pump actually does.  They are free energy in the same sense that they don't use fuel but they do use gravity just like the hydroelectric plants do.  They just do it much less efficiently.  They also require a fair amount of head pressure so you can't put several of them in line in a stream.  The lower ones would not get the pressure they need to operate.
stevensrd1
Did you read the info through. Your speaking as if we only use one single ram pump. You can use as many ram pumps as you want, they can all still be connected or getting their water from the same lower reservoir. That allows you to get as much water to the top as quick as you want. Imagine it like this if i have one bucket and dump one bucket into a pool thats not much water. But if I dump 10 buckets all at once then I have a lot of water in the pool and have it in the pool all at once. By using more ram pumps you can have as much water as you want reaching the top at any point in time, and if its still not enough water just use more ram pumps. Thats the secret right there.
https://en.m.wikipedia.org/wiki/Bom_Jesus_do_Monte_Funicular
https://de.m.wikipedia.org/wiki/Walchenseekraftwerk
      Walchensee : Ober-Becken         Kochelsee : Unter-Becken
New York : " skyscraper" water delivery to 40./ 50...... stage in the 20' of the last century ?
Toribio Bellocq, Lloyd Crump, .....
http://rexresearch.com/bellocq/bellocq.htm
....... " The waves so set up are comparable to sound waves or waves of electric energy. "....
https://patents.google.com/patent/US2855860A/en
https://en.m.wikipedia.org/wiki/Tesla_turbine
Prantl, Coanda + Coriolis Effekt + Magnus Effekt
https://simple.m.wikipedia.org/wiki/Syphon.   Up or Down  ?
https://en.m.wikipedia.org/wiki/Thermosiphon
http://www.aenertec.com/talon_rms.htm
                                        All-in-ONE : motionfree pumps= tubes
https://worldwide.espacenet.com/data/publicationDetails/biblio?DB=EPODOC&II=3&ND=3&adjacent=true&locale=en_EP&FT=D&date=19760115&CC=DE&NR=2429086A1&KC=A1
