the 25 Euros perpetuum 50 W ( min. !) generating engine
Started by lancaIV, January 21, 2019, 06:23:00 AM
Not much power per day ? 50W x 24h = 1200 W*h / day
Sufficient as primary power source for 80 sqm room heating ( West-Europe, coastal area), www.oeko-energie.de  and  www.mtbest.net household appliances electric energy demand per day and warm water delivery for 3 capita
Construction : Mukherjee DC motor concept
Material input : Helmut Schiller DC input motor( AC output alternator)
                            3000 RPM , 100W nominal F= B*I*L
                            Controle Unit                         F'= 2B* I*L , non rotative H.Schiller DC motor, rotor/stator fixed
                            device start : by " hand crank "
Material weight estimation : motor 150 gr. + controle unit  200 gr.
                                                   China / India : alibaba/ aliexpress 37,5 Euros/Kg  pm motor and generator average
" perpetuum" lifetime : bearings 3000 RPM ca.  20000 hours ( 1 year : 8766 hours )                                         improvement : www.bufo.ru surface treatment/ coating
                                         NUFM : 2x                      Geo : 4-5 x
                                          coils                           ca. 100000 hours ( ~ over 10 years permanent )
  less RPM clearly possible = more material weight ( costs ! ) 1500 RPM ~ 3000 RPM device x 2 factor  1000 RPM~ 3000 RPM device x 3 factor
hand crank force : human counter body force ?
Non rotative = mechanical no movement = Transformator kind :
https://patents.google.com/patent/DE19804277C2/pt-pt
    https://tesla3.com/hilden-brand-jack/          but here  I and H- core
https://patents.google.com/patent/DE3938577A1/de  U -core + " L = ( WE + WM)  x Hz "
_____________________________________________________________________
My private household calculation :
80 sqm 4000 Wattp heat per hour to 10 Watt per hour electric storage energy need
warmwater 3 capita : 1350 KWh per annum to 25 Wh per day electric storage energy need
kitchen appliances, light : 1500 Wh per day to 150 Wh  per day electric storage energy need
        ( 10 x 24 ) + 25 + 150 = 415 in W* h electric storage energy per day : generating 1200 W* h per day
                                                             ~ 12 Volt x 85 Ah battery
        enough is enough
Energy storage :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=20021231&CC=US&NR=6501093B1&KC=B1#
and " citing documents"
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20161027&CC=US&NR=2016315367A1&KC=A1#
Radiant Energy or Blacklight or wattfree energy or displacement current :                   to electricity conversion
C.0.P.  : beginning small
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=9&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900201&CC=DE&NR=3817730A1&KC=A1#
C.O.P. :  2 x                                    70W out
                                             35 W lamp in
Marzahn
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Paul+Heinrich+marzahn&IN=&CPC=&IC=
C. O. P. :  4,166                                 650 W ( 5 panels x 70W x reflector amplification)  out
                                                            156 W (12 x 13 W lamps ) in
up to     8,0.                    by solar panel coating and 2019 fluorescent lamps use
https://m.youtube.com/watch?v=cBFAe3rArCg             as lamp/-s drive
                                 7W + 8W LED  output
                                  Volt * Ampere input  ?
                      "Agitation-/Stimulation-" C.O.P.:   375 x  ?   ( theoretical nominal/ measure numbers 1:1 )
   Mahrzahn  optimized + Morin drive : C.O.P. :
        3000 x
                                   Radiant Energy to DC Electricity receiver + converter
10%. error  quote : 2700 x     90%    error  quote : 300 x.    99%    error quote :  30 x    99,9% error quote : 3x
defensive research & experimenting with great trial chances and low risks : Analytik, Stochastik
sinergicus
which is the pattent you speak in the links you posted ???? if I click on  this  https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Paul+Heinrich+marzahn&IN=&CPC=&IC=    will gave me  a full page  of another links with  more   pattent number applications in  german language......
where is the patent about you speak   here ?: C. O. P. :  4,166                                 650 W ( 5 panels x 70W x reflector amplification)  out
Quote from: sinergicus on January 22, 2019, 07:30:22 AM
which is the pattent you speak in the links you posted ??? ? if I click on  this  https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=Paul+Heinrich+marzahn&IN=&CPC=&IC=    will gave me  a full page  of another links with  more   pattent number applications in  german language......
Hello sinergicus,
these several " utility model(l) " application by Paul Heinrich Marzahn shows several possibilities and their
improvements, because this it is ever important to see the technical process and the device effect  !
Publications in German, but the espacenet site offers a translation possibility :
650 W ( 5x solarcell modules a 70W + radiation amplifying mirrors) : (12 x 13 W lamps) = 4,166
"SELECT LANGUAGE":
https://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=29520064U1&KC=U1&FT=D&ND=3&date=19960314&DB=EPODOC&locale=en_EP#
F.e.  in "English " :
http://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=U1&LOCALE=en_EP&NUMBER=29520064&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
7W + 8W LED lamps output : 100% - 0% comparison with direct plug !
Comparison input " Morin transformer" from plug / direct plug
by "Wattmeter"f. e.  :
https://www.ebay.de/itm/New-UK-US-EU-Power-Energieverbrauch-Wattmeter-Stromverbrauch-Monitorsockel-LCD/401629935853?hash=item5d830278ed:m:msGyc97kzTMD1ua2wrBpcyg&var=671374784622&redirect=mobile
70Watt solar panel enroled as tube and 35 Watt fluorescent long 1 mtr. lamp
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=19900201&CC=DE&NR=3817730A1&KC=A1#
Mahrzahn improved by reflector/ mirror use the "5-7%" conversion limitation by " artificial light-fall doubling"
( factor 1,85 ) in the 80/90' !
        COMPARISON
Baquero Menendez used  240W/1,8 qm ~10% efficiency solarpanels
                                         ( theoret. solar light spectrum : 1333 W/ sqm )
                                       8 x 240W  and 1x 500 W lamp
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=20100615&CC=ES&NR=2341161A1&KC=A1#
It shows that for the same output 4x 240W + coating + reflector are sufficient
This then as DC source for the " inverter concept" like http://www.patentsencyclopedia.com/app/20090079393
