Newton's Magnets
Started by Floor, February 01, 2019, 02:25:37 PM
Low-Q
@Floor
I think your idea is interesting enough to do some more testing. I'll do a test with your design where I use three discs/gears with connection rods to crank shafts that moves the opposing magnets as pistons back and forth at the same time as the third magnet is moving back and forth with right timing.
Btw, is "Newton's magnets" something you figured out or named yourself, or is it Mr. Newton who discovered this? If I google "Newton's magnets" I cannot find anything, no illustrations, other than this thread.
Vidar
Floor
@ LowQ
Please give me your response to this question below. I'm not trying to force any ones
hand  here, but I want to know who has both brains and courage on this topic.
I am not asking if the design is over unity, just if it does what is stated.
to the best of your knowledge
"Do the Newton's magnets interactions in fact enable those magnets, as described in the attached Newtons magnets PDF file animation, to move in the manner illustrated, with what is near to, a freedom from a resistance by the magnetic forces present.
next
Believe it or not.....
Do that, and you will end up with a no O.U. result.
Don't be stuck in the idea that continuous motion is needed, or it would
work better.
It is one reason why no one has tried this in the various ways I describe.
I understand people's inclination to make these interactions into
continuous motion devices.  Conserve momentum, and all that.
BUT THAT IS, ABSOLUTELY NOT THE WAY THEY FUNCTION.
     THEY ARE NOT CONTINUOUS MOTION DEVICES.
                                    AND
THEY DO NOT HAVE CIRCULAR OR ROTATEING MOTIONS.
Next
The reason I call the Newton's magnets design that, is because it is based
on Newton's laws of motion.
best wishes
      floor
Floor
                                                     Newton's magnets
                                              Equal and opposite forces.
It requires the same energy expenditure to pull two magnets in attraction apart,
as those magnets delivered during their attraction to each other.
                     But allso
Because Newtons laws are valid, and because of the  two pole nature of permanent magnets...........
We can change the positions of two magnets, which are in close proximity to one another,
without doing work against the magnetic forces between those  magnets.  To see an example of this illustrated,  open the PDF attached below.
To see Newton's magnets actually done, watch this video, titled "amazeing"  @
                          https://www.dailymotion.com/video/x6gzr2q
or this variation of the Newton's magnets, watch this video, titled "RtAngSld"   @
                          https://www.dailymotion.com/video/x59r978
or to see a completely different method of neutralizing magnet force as in this video,
titled "TDForceDiagramed"
                            at 2 minutes and 50 seconds into the video
watch                  https://www.dailymotion.com/video/x6wfk0d
or to see yet another, completely different method of neutralizing magnet actions (by brute force)
see this video @
                          https://www.youtube.com/watch?v=rRmbekUqJcs
        floor
Floor
@ all readers
On a more personal note, I guess its high time that I accept and
acknowledge the contributions and support of the others involved.
             And .....
Since this stuff really is open source and since any one may do with it
as THEY see fit,  well then I guess I need to get out of the way, respect,
and know that my peers, really do know what they are doing, just as much as I.
          And ...
To for me to relax have some fun and some f ing gratitude for it all !
You guys got this ?
           Ok, Thanks
floor
Acca
Newtons laws are NOT valid ....
You have been brain stamped with Education DOGMA..  Now what So called scientists have rubber stamped
this in to all educational forms is impossible to remove..  Now this is not an insult on you, just a shock
reset if you can think out beyond that mind prison construct..  I was there too...
I will not say any more as I an not an educator to anyone... Take care..
Acca...
