Magnetic wheel by steel shielding
Started by vineet_kiran, February 02, 2019, 08:15:48 AM
vineet_kiran
Quote from: nix85 on March 08, 2021, 09:24:46 AM
Here is another video of the same material, it seems it attracts magnet a bit, at least on the ends.
https://www.youtube.com/watch?v=SQw-nk6nYs0
All three videos are made in 2011.   By this time he should have built a working perpetual all magnet motor.  Do you think it is real?
nix85
Quote from: vineet_kiran on March 08, 2021, 07:55:17 PM
I have no doubt material is real and also no doubt it is totally not needed.
Let it here be stated there are infinitely many ways to make a working perpetual motor/generator, just as there are infinitely many ways to fail.
nix85
Most important of all concepts in creation is
R E S I S T A N C E
Without this primordial concept nothing could manifest.
Through resistance God / Self creates, by interference patterns in the primordial cosmic force field of infinite frequency and amplitude resisted by the second order energies along 6 axis of TIME.
Below is Bentov's cosmic egg and universe wide spark gap.
It is also a picture of primordial paradox.
Consciousness does not really want to split, polarize itself, but it does want it cause duality allows it to better know and appreciate the original state of perfect unity.
SCALE OF CREATION ACCORDING TO BENTOV
One egg universe as seen below + 48 more similar ones in a great 7 level spiral make one cell.
15 such cells make double tetrahedron structure.
Thousands of such structures make even bigger cell and countless number of such bigger cells make the first of 7 COSMIC PLANES.
vineet_kiran
Quote from: nix85 on March 09, 2021, 01:54:01 AM
Magnetic field is non physical entity hence it cannot be blocked by any material object.   Magnetic materials like iron do not block magnetic field but provide path of least resistance to magnetic flux to reach the other (opposite) pole.
If at all a magnetic field is to be blocked,  it can be done only by using another non physical field.   Is there any field which can block magnetic field?
antijon
In the first video the L shape suggests he's using it as a "channel" to direct the fields. Why else would he need a stack of 8 magnets to repel a single magnet? Looks like he's using the stack to bring the lower pole closer to the bottom of the L.
This could be done with steel, too, except it would be hard to pull apart. Steel at the right thickness could act as a channel for one magnet, but as a second magnet is brought closer in repel, the steel saturates, leaving only a slight repelling force. This is similar to the neutral zone.
This is all speculation, but his material could be nonmagnetic, like aluminum, to prevent tackiness. But if it included a low amount of small iron fillings, it might behave this way. Don't know why else a magnet isn't tacky on the flat side, but is attracted to the side of the L, except that the magnetic path is longer allowing the side to form a stronger pole.
